Comp Cams help #2417528
12/12/17 07:23 PM
12/12/17 07:23 PM
Northeast
Racer68 Offline OP
Racer68  Offline OP
Northeast
I need to call CompCams. I'd like to speak to a "hemi guy". Any recommendations?
Re: Comp Cams help [Re: Racer68] #2417530
12/12/17 07:27 PM
12/12/17 07:27 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Why would you call Comp Cams for a Hemi Guy?
Re: Comp Cams help [Re: Racer68] #2417538
12/12/17 07:38 PM
12/12/17 07:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Call Barton.
Re: Comp Cams help [Re: rickraw] #2417615
12/12/17 09:57 PM
12/12/17 09:57 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Good luck! I went to the trouble of filling out all the specs online to get them to recommend a cam for my 505. No one replied. Called the tech line and got what sounded like a 15 year-old. His "recommendation" was so far off base I laughed.
'63 Dodge 330
11.19 @ 121 mph
Re: Comp Cams help [Re: Racer68] #2417820
12/13/17 09:43 AM
12/13/17 09:43 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Heck just pick your own lobe...how hard can it be?
http://www.compcams.com/Technical/Catalogs/CamLobeMasterCatalog.pdf
Re: Comp Cams help [Re: Medlock51] #2417822
12/13/17 09:58 AM
12/13/17 09:58 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Call Scott Brown.
Re: Comp Cams help [Re: fbs63] #2417824
12/13/17 10:26 AM
12/13/17 10:26 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Originally Posted By fbs63
Call Scott Brown.
I agree 100% up
Re: Comp Cams help [Re: Racer68] #2417958
12/13/17 02:43 PM
12/13/17 02:43 PM
Northeast
Racer68 Offline OP
Racer68  Offline OP
Northeast
Thanks a lot for the name. I'll ask for him.
And no, I'm not looking for Comp to design a cam for me. I had a question for them about cores.
Re: Comp Cams help [Re: Racer68] #2417999
12/13/17 04:12 PM
12/13/17 04:12 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Scott is not with Comp Cams. Scott does his own stuff. Not sure who 's cam cores he uses, but he doesnt work for Comp. Last I knew, I think he was involved with a Buick or Olds shop maybe? ( still does Mopars I am sure)
You will most likely be sadly disappointed if you call Comp directly. You will have trouble getting person and also the right person.I would strongly suggest calling a shop that deals with Comp a lot directly like Dwayne Porter or someone. They have a better list of " who's who" so to speak. If you call yourself, its a 50/50 chance of getting correct answer. Unfortunately, the tech lines, well,,, arent always very good. Not sure what you are doing, but there is always Bullet, Cam Motion and LSM that do a lot of stuff with cores. The Comp group has purchased Crane Cams, so not sure if that helps or hurts their efforts.
RIP Monte Smith
Re: Comp Cams help [Re: CompWedgeEngines] #2418002
12/13/17 04:17 PM
12/13/17 04:17 PM
When did they buy Crane?
Do they still own Lunati?
Re: Comp Cams help [Re: CompWedgeEngines] #2418003
12/13/17 04:18 PM
12/13/17 04:18 PM
an8sec70cuda Offline
iagree Dwayne Porter (Fast68plymouth) is the man you need to talk to. 802-951-1955 He owns Porter Racing Heads and deals directly w/ Comp Cams. I couldn't be happier w/ the cams he's spec'd for me.
My experience w/ Scott Brown wasn't so good.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Comp Cams help [Re: an8sec70cuda] #2418068
12/13/17 05:52 PM
12/13/17 05:52 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
iagree X2
Talk to Dwayne.
The cam I bought from Barton was a disappointment.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
