High voltage charging #2417655
12/12/17 11:03 PM
12/12/17 11:03 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
I moved the battery of my 70dodge to the trunk the same time I swapped out my 6 cylinder for a 318. Any reason why when I test at the battery now it's off the charts charging it? I got an adjustable voltage regulator but I think this is not solving the problem just masking it? Any thoughts? Would moving the battery cause this?
Re: High voltage charging [Re: z70dodge] #2417658
12/12/17 11:09 PM
12/12/17 11:09 PM
yes if the cables are too small/and or poor connections. fastest check would be to take the battery back up front & jump it to the block/starter relay & see if thing straighten out. otherwise I would check the voltage drops at the alt/reg & at the battery.
Re: High voltage charging [Re: RapidRobert] #2417662
12/12/17 11:15 PM
12/12/17 11:15 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Will do! You thank you! Going to do that now.....
Re: High voltage charging [Re: z70dodge] #2418343
12/14/17 04:03 AM
12/14/17 04:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What is the voltage reading at the battery ? How high is it reading ? Ron
Re: High voltage charging [Re: z70dodge] #2418346
12/14/17 04:23 AM
12/14/17 04:23 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's the amps that you should worry about. The voltage on my battery charger shows 16V on a 12V battery when it is nearly charged and taking less than 5 amps? After the charger shuts off it shows almost 14V.
Re: High voltage charging [Re: Dave Hall] #2418347
12/14/17 04:30 AM
12/14/17 04:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes but because the OP said its Off the Chart it would be nice to know just what he read. And the voltage reg controls the alt output (amps) by measuring the voltage at its terminal from the blue wire on an electronic reg. But I am curious what the OP checked to see it as off the chart ? Ron
Re: High voltage charging [Re: 383man] #2418350
12/14/17 04:53 AM
12/14/17 04:53 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I hear ya Ron! Definitely need to know what kind of charts we're talking about. Battery type and voltage? Adjustable regulator? I don't think too small of a gauge wire would be a cause. I think the wire would get hot if anything.
