Re: Comp Cams help
[Re: Racer68]
#2417530
12/12/17 07:27 PM
12/12/17 07:27 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
I need to call CompCams. I'd like to speak to a "hemi guy". Any recommendations? Why would you call Comp Cams for a Hemi Guy?
Re: Comp Cams help
[Re: rickraw]
#2417615
12/12/17 09:57 PM
12/12/17 09:57 PM
Posts: 4,664 Wichita
GY3
Wichita
Good luck! I went to the trouble of filling out all the specs online to get them to recommend a cam for my 505. No one replied. Called the tech line and got what sounded like a 15 year-old. His "recommendation" was so far off base I laughed.
Re: Comp Cams help
[Re: Racer68]
#2417999
12/13/17 04:12 PM
12/13/17 04:12 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Thanks a lot for the name. I'll ask for him.
And no, I'm not looking for Comp to design a cam for me. I had a question for them about cores. Scott is not with Comp Cams. Scott does his own stuff. Not sure who 's cam cores he uses, but he doesnt work for Comp. Last I knew, I think he was involved with a Buick or Olds shop maybe? ( still does Mopars I am sure) You will most likely be sadly disappointed if you call Comp directly. You will have trouble getting person and also the right person.I would strongly suggest calling a shop that deals with Comp a lot directly like Dwayne Porter or someone. They have a better list of " who's who" so to speak. If you call yourself, its a 50/50 chance of getting correct answer. Unfortunately, the tech lines, well,,, arent always very good. Not sure what you are doing, but there is always Bullet, Cam Motion and LSM that do a lot of stuff with cores. The Comp group has purchased Crane Cams, so not sure if that helps or hurts their efforts.
RIP Monte Smith
Re: Comp Cams help
[Re: CompWedgeEngines]
#2418002
12/13/17 04:17 PM
12/13/17 04:17 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
When did they buy Crane? Do they still own Lunati?
Re: Comp Cams help
#2418003
12/13/17 04:18 PM
12/13/17 04:18 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Dwayne Porter (Fast68plymouth) is the man you need to talk to. 802-951-1955 He owns Porter Racing Heads and deals directly w/ Comp Cams. I couldn't be happier w/ the cams he's spec'd for me. My experience w/ Scott Brown wasn't so good.
Re: Comp Cams help
[Re: an8sec70cuda]
#2418068
12/13/17 05:52 PM
12/13/17 05:52 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Dwayne Porter (Fast68plymouth) is the man you need to talk to. 802-951-1955 He owns Porter Racing Heads and deals directly w/ Comp Cams. I couldn't be happier w/ the cams he's spec'd for me. My experience w/ Scott Brown wasn't so good. X2 Talk to Dwayne. The cam I bought from Barton was a disappointment. Mark
