06 Ram drivers door popping noise when closing #2417291
12/12/17 12:57 PM
12/12/17 12:57 PM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
My drivers door makes a popping noise when closing (not every time). It sounds like the upper hinge but I cannot see any issues with it. Usually you can see movement from wear but seems to work smoothly. I noticed that the pillar post that the hinge is bolted to seems to have movement when opening and closing. Anyone have the same issue?
Re: 06 Ram drivers door popping noise when closing [Re: mopars4ever] #2417533
12/12/17 07:30 PM
12/12/17 07:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you lubed the hinges since this began?
Re: 06 Ram drivers door popping noise when closing [Re: mopars4ever] #2417554
12/12/17 08:27 PM
12/12/17 08:27 PM
md
md
I sprayed them with WD40 and put some lube on them. No difference.
