Proper power steering pump #2417308
12/12/17 01:18 PM
12/12/17 01:18 PM
S.florida
Jupiter331 Offline OP
S.florida
Can someone tell me which is pump is the right one for a 70 440 challenger with ac. A picture with the right brackets would be great too. Thanks
Re: Proper power steering pump [Re: Jupiter331] #2417314
12/12/17 01:35 PM
12/12/17 01:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well:
Re: Proper power steering pump [Re: Jupiter331] #2417320
12/12/17 01:42 PM
12/12/17 01:42 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and should be attached high to the water pump provisions
something like this ( yes I know not the correct AC compressor, but steering pump mounts are correct )
this specifically is the Saginaw pump
Re: Proper power steering pump [Re: Jupiter331] #2417627
12/12/17 10:24 PM
12/12/17 10:24 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is the right Saginaw pump but wrong reservoir. Bouchilon sells the brackets and pulley you need. The reservoir has the return line clocked straight out at the nine o’clock position.
Re: Proper power steering pump [Re: Jupiter331] #2417828
12/13/17 10:44 AM
12/13/17 10:44 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that's correct, for the year the correct pump reservoir is round... just like this
but pump assembly is the same on both
Federal pump looks slightly like this, but one of the hoses conects in front of the pump. Saginaw gets both hoses conected on back side
