92 Ramcharger no start issue #2416929
12/11/17 07:52 PM
12/11/17 07:52 PM
Beertown, WI
Slingshot Offline OP
Beertown, WI
Here's the issue. 1992 Ramcharger 318 magnum-started fine all year until late October. Replaced fuel pump since the the cheap discount one I put in 2 years ago seemed to stop working after I ran the tank down. Still minimal fuel pressure at the rail. Started, but ran on 2 cylinders (it felt like). Gave it a tune up since the plugs were fouled(plugs, wires, cap rotor). Still won't start right. FuEl pump relay clicking on and off continuously-if I pump gas and hold the pedal down 1/4 it will eventually fire on a couple cylinders, and usually smooth out after a while. Afraid to run it since it died while on a test drive.
Replaced fuel pump, asd and fuEl pump relays, distributor pickup, plugs, wires, cap, rotor, and ignition coil. Where is the parasitic draw that is kicking that relay? What am I missing? I'm going nuts with this since I have to park it on the street and don't have place to store it yet.
Any gurus out there that may know something about electronic issues with theseveral old bombers? I have about 240,000 miles on it so far.
Do you angle park in a parallel universe?
NHRA Division 3 Announcer
Great Lakes Dragaway
DJ-Saturday Morning Cartunes/The Gearhead Show
6-9a.m. Saturday mornings
WMSE Milwaukee 91.7fm
www.wmse.org
Re: 92 Ramcharger no start issue [Re: Slingshot] #2417096
12/12/17 12:47 AM
12/12/17 12:47 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Check the fuel pressure of your new fuel pump. Its unfortunate, but these days, new does not necessarily mean its good. If the fuel pressure is low, it won't start or run worth a darn.
The next thing I would check would be where the fuel pump wires pass through the bulkhead connector. A little corrosion on those wires will cause a lot of problems. Dakota's of that era had a problem with the wire junction under the battery box for the wires that supplied power to the coil, crank sensor and dist pickup. That junction would be heavily corroded and the wires would break off giving a no start condition. Maybe the junction on your truck is just badly corroded and is causing incorrect readings for the computer. Gene
Re: 92 Ramcharger no start issue [Re: Slingshot] #2417378
12/12/17 03:22 PM
12/12/17 03:22 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
When you said rapidly clicking relay, I immediately thought of a ECM problem. For some reason on the 92-93 trucks a capacitor fails and creates a no start condition when under 55 or so. I've had 2 fail like that on my 92. Easy to test:
1.turn ignition on and see if check engine light comes on. it should as part of the test sequence of the ECM
2. Can also warm up the ECM with a hair dryer or similar- if it starts right up, you found the problem
Otherwise, a loose/corroded connection is next
Re: 92 Ramcharger no start issue [Re: jerseybud] #2417776
12/13/17 03:16 AM
12/13/17 03:16 AM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Had one doing the same thing you're describing..it was the ECM.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: 92 Ramcharger no start issue [Re: jerseybud] #2418734
12/14/17 10:51 PM
12/14/17 10:51 PM
Beertown, WI
Beertown, WI
The check engine light doesn't come on until after I crank it a whole bunch. Dunno if on-off of the ignition switch helps or not, but eventually the light lights up and flickers with the rapidly actuating relay. I hold the pedal down about 1/2, keep cranking, and eventually it starts, sounds like it's firing on 1 cylinder, and during each firing event, the check engine light goes on and off. Eventually it smooths out, the light stays off, and it runs fine, although it idles a little low. Craziest crap I've ever seen. Sounds like an ECM?
www.wmse.org
Re: 92 Ramcharger no start issue [Re: SuperStockWagon] #2418735
12/14/17 10:52 PM
12/14/17 10:52 PM
Beertown, WI
Beertown, WI
And a big thank you to everyone who replied! It all helps!
www.wmse.org
Re: 92 Ramcharger no start issue [Re: Slingshot] #2418915
12/15/17 11:17 AM
12/15/17 11:17 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Textbook for bad capacitor in ECM. need to fix it or replace or use a hair dryer to warm it every day. Model years are 92-93 with 5.2. Can run 94-95 but it wont run right.
Somewhere on the net is instructions of how to fix it on a jeep site. not for the faint of heart or those who struggle with precise soldering
Re: 92 Ramcharger no start issue [Re: Slingshot] #2418935
12/15/17 12:24 PM
12/15/17 12:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree about it being the PCM as I worked at a Dodge dealer for 24 years and seen the PCM do that a few times. Also make sure all the grounds are good and the PCM grounds. Good luck , Ron
