Solid roller lifters small block #2416818
12/11/17 04:29 PM
12/11/17 04:29 PM
Denver CO
bennydodge Offline OP
Denver CO
Anybody run the comp 8043-16 solid rollers? Any grinding needed? I need to replace my Herbert lifters. Looking to hear from people that have ran these or something else that drops in/no grinding.
73 Challenger 340(416),E-heads, 727, 3.23 SG
2015 Challenger R/T classic B5, wife's car
2010 Ram 3500 Crew Cab SLT dually 4X4
2016 Challenger Hellcat Redline Red A8
Re: Solid roller lifters small block [Re: bennydodge] #2416820
12/11/17 04:32 PM
12/11/17 04:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I haven't but from the looks of them I can't imagine any grinding would be needed. On the 828-16s any grinding needed is because the link bar is on the outside of the lifters, on the 8043s the link bar is moved to the other side to help with clearance, they also have better oiling than the 828s if I am not mistaken.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: Solid roller lifters small block [Re: Bad340fish] #2416825
12/11/17 04:41 PM
12/11/17 04:41 PM
Denver CO
Denver CO
I noticed the moved link bar as well, but figured asking on here would quell any doubts. They look like nice lifters for street use.
Re: Solid roller lifters small block [Re: bennydodge] #2416842
12/11/17 05:20 PM
12/11/17 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No grinding needed.. they drop in with the head off
wave
Re: Solid roller lifters small block [Re: bennydodge] #2416925
12/11/17 07:46 PM
12/11/17 07:46 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
BAM Products Lifters....MRL was selling them, now you must be a professional engine builder to buy from BAM directly (no retail).
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Solid roller lifters small block [Re: MR_P_BODY] #2416968
12/11/17 08:51 PM
12/11/17 08:51 PM
Denver CO
Denver CO
wave
Ah yes, forgot about the heads-I've got Edelbrocks. Would prefer to find some that don't require head removal.
Re: Solid roller lifters small block [Re: Adobedude] #2416970
12/11/17 08:52 PM
12/11/17 08:52 PM
Denver CO
Denver CO
Originally Posted By Adobedude
BAM Products Lifters....MRL was selling them, you can them from BAM direct now.
These are also sold by Hughes?? They look the same.
Re: Solid roller lifters small block [Re: bennydodge] #2416982
12/11/17 09:12 PM
12/11/17 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your deck has been cut you might have a issue..
at least on my W-2s there was.. I did some
grinding to get them to clear... I wanted to
set them up so I could change rollers while I
wason drag week.. I could get them out.. but
it was a PITA.. but I changed over to a FT
cam which are shorter.. no problem now.. I
am setting up my set of W-5s to put on just
for the weight difference..I clearanced them
for rollers also(I had them set up but ran
into some problems with those heads and put on
my W-2s)
wave
Re: Solid roller lifters small block [Re: bennydodge] #2416984
12/11/17 09:16 PM
12/11/17 09:16 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Looks like it...They're damn nice lifters, I've been running them for about 3 years.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Solid roller lifters small block [Re: bennydodge] #2416993
12/11/17 09:31 PM
12/11/17 09:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
I ran the 8043's in my R3 engine. 400+ runs between rebuilds, no issues.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Solid roller lifters small block [Re: Triple Threat] #2416997
12/11/17 09:39 PM
12/11/17 09:39 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Would prefer to find some that don't require head removal.""
What are the chances that going to a SR would require head removal just to swap out the lifters? Or does it just require mockup to find out for sure?
Re: Solid roller lifters small block [Re: YO7_A66] #2417001
12/11/17 09:44 PM
12/11/17 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I mocked up mine when I was building the engine..
its close on a lot of roller but 2 of the sets
I have just wouldnt come out
EDIT
It only took about 1 1/2 hours grinding to get
them to clear
wave
Re: Solid roller lifters small block [Re: MR_P_BODY] #2417005
12/11/17 09:54 PM
12/11/17 09:54 PM
Denver CO
Denver CO
Thanks for replies guys. It's been around 9 years since I was last in the motor so I probably don't remember every detail, but the Doug Herbert solid rollers went in with the heads on.
