CSR Super Shields 826 #2416329
12/10/17 05:46 PM
12/10/17 05:46 PM
PA
Scully Offline OP
Scully  Offline OP
PA
How well does it fit early b bodies.
Re: CSR Super Shields 826 [Re: Scully] #2416339
12/10/17 05:59 PM
12/10/17 05:59 PM
fullmetaljacket Offline
You have to cut off the two front transmission assembly line ears flush to the trans case (about a 1/2 Lb shaved) and then after that, it should only need a little body hammer work to the seam edge of the trans tunnel floor underneath to flatten it for clearance. This is only on a standard engine K frame positioned situation. I had to cut out and body shape/form a new half trans oculus tunnel because my engine is set back 2" inches. I have a 65' post Dodge.
Re: CSR Super Shields 826 [Re: Scully] #2416412
12/10/17 09:25 PM
12/10/17 09:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also set back the hemi in my 63 Plymouth.Needed to massage the point where the tunnel meets the firewall.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
