Re-drilling axles for 5/8" studs
#2416052
12/10/17 03:18 AM
12/10/17 03:18 AM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
I have Strange axles that need 5/8 studs, can it be done without super expensive tooling? Boring the holes is no problem but I'm concerned about tapping.
Steve
Photobucket sucks
Re: Re-drilling axles for 5/8" studs
[Re: Dave Hall]
#2416114
12/10/17 11:56 AM
12/10/17 11:56 AM
72chrgrally
Hamilton,Ont
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles.
Photobucket sucks
[Re: 72chrgrally]
#2416212
12/10/17 02:57 PM
12/10/17 02:57 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles. Of course they do.You might consider bringing your axles to a machine shop for precision.
[Re: 72chrgrally]
#2416298
12/10/17 04:48 PM
12/10/17 04:48 PM
72chrgrally
Hamilton,Ont
My good friend is a machinist and he told me cutting the holes wasn't an issue but he did not have a tap he was confidant in to cut the threads. I really don't want to buy a $300 tap to thread 10 holes.
Photobucket sucks
[Re: The Shadow]
#2416366
12/10/17 07:04 PM
12/10/17 07:04 PM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
I have Mark Williams axles years ago I broke the 1/2 studs I had, i sent them back to Mark Williams and had them redrill the axles and install 5/8 studs and haven`t had a problem since it wasn't expensive. Perhaps Strange could do it for you
[Re: 72chrgrally]
#2416380
12/10/17 07:41 PM
12/10/17 07:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What does Strange want to do it? I inquired about it via e mail and they suggested buying new axles. If thet wont do it send them over to Mark Williams or on of the other axle companies.. dont bother to try it yourself
[Re: 72chrgrally]
#2416395
12/10/17 08:19 PM
12/10/17 08:19 PM
72chrgrally
Hamilton,Ont
I'll do some more research, a friend of mine has done his own axles in the past and he has a tap he claims will do the job. I'll let everyone know how it goes. If I end up needing to get axles I'll be narrowing my rear end another 2".
Photobucket sucks
[Re: 72chrgrally]
#2416476
12/10/17 10:35 PM
12/10/17 10:35 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Tried to machine Strange axles by hand one time, only one time. Many years ago. That job is listed in the Strange catalog as part #A1065 for $80.
[Re: 72chrgrally]
#2416644
12/11/17 04:07 AM
12/11/17 04:07 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have Strange axles that I bought years ago for my Barracuda. Last year I found I broke 1 stud and bent the other 4 on one axle. As I had did business with Moser before I sent them to them to have the holes re drilled for 5/8 studs. Moser called and said the axle flanges were to hard to drill, they didn't know why. So I called Strange, they said ship them, they could do it. Called Moser, asked if they could ship the axles to Strange to avoid shipping back to me then reshipping to Strange, no problem. Moser called Strange and Strange told them they wouldn't accept them as I didn't have an account with them. I asked why that Strange didn't tell me that when I was talking to them? Moser asked Strange the same question and the guy got nasty . So I called Strange back, got an account set up to send the axles back to them. While I was on the phone I questioned again weather they could re drill / tap the hardened flanges. Answer was yes, continuing with the conversation , why don't you check with the machinist who does the work. He came back with [ As long as they haven't been welded on ] I replied that the bearing retainer ring was tack welded on from them. Then came the screaming. WE DON'T DO AXLES WITH BEARINGS ON THEM, [ Moser does ] YOU HAVE TO REMOVE THEM, IF WE DON'T LIKE THE WAY YOU CUT OFF THE RETAINER WE WON'T DO THEM AT ALL. I didn't say it but F U Strange. Called Moser back and just had them ship them back. Installed new ARP 1/2 studs. Moser took all the dimensions from my axles so if I need another set they WILL get the call.
[Re: 72chrgrally]
#2416791
12/11/17 03:37 PM
12/11/17 03:37 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Part #A1065 says "Axles must be sent in with bearings and studs removed".
Strange says "Do NOT weld on an axle".
They won't touch an axle if either instruction is ignored. Doing anything to an axle that has been welded on, or that has been hacked up when the wedding ring is removed, and then sending it back, is a huge liability when the thing breaks.
Following instructions and sending them back to the guy who made them would have made it easy.
[Re: SportF]
#2417021
12/11/17 10:27 PM
12/11/17 10:27 PM
MR_P_BODY
The pair of Strange axles that are in my car right now have about a 1/4 turn of twist in them.. all right near the splines(within about a 1/2").. still going strong
[Re: 72chrgrally]
#2417024
12/11/17 10:31 PM
12/11/17 10:31 PM
rowin4
I bought the axles, retaining axle plate and bearings installed from Strange. They tack welded the retainers on.
[Re: SportF]
#2417157
12/12/17 02:25 AM
12/12/17 02:25 AM
rowin4
I have brought this up before, if you weld (or just tack) on hardened steel it will more than likely break, in 6 months or so. Depending on the amount of heat, and time, it brittles, and failure is on its way. That's pretty much true. Looking back , I bought these Strange axles back in 1975, No Twisting of the splines, never had to change the bearings . Thousands of wheels up 1/4 mile runs. I doubt if there going to snap off anytime soon.
[Re: rowin4]
#2417238
12/12/17 10:28 AM
12/12/17 10:28 AM
Posts: 5,894 Florida
Locomotion
I'd recommend the Moser option as well. As racers themselves, they are very customer oriented. Anything can break eventually. I had a 2,850lb Challenger with a Dana 60 & 35 spline Strange axles. Car had very limited time with a 440/4 speed before I got it, but my combo was a 360/W-2/auto footbraking and running as fast as 10.22. I broke an axle after about 9 years of almost year-round twice per week racing here in Florida while doing well. I think I wore out a ring & pinion or two in that time as well! I've used Moser axles in my 3,540lb+ Dart Sport for around 17 years, but have upgraded to lighter axles a few years ago. Never a problem with the axles. But I'm going to a Moser Dana 60 in it and my Aspen so I don't have to worry about the ring & pinion anymore. Easier to check too! With my less hectic schedule, it might be the last time I change anything with the rear besides fluid.
[Re: rowin4]
#2417265
12/12/17 12:20 PM
12/12/17 12:20 PM
Posts: 1,211 Minn
SportF
Minn
I have brought this up before, if you weld (or just tack) on hardened steel it will more than likely break, in 6 months or so. Depending on the amount of heat, and time, it brittles, and failure is on its way. That's pretty much true. Looking back , I bought these Strange axles back in 1975, No Twisting of the splines, never had to change the bearings . Thousands of wheels up 1/4 mile runs. I doubt if there going to snap off anytime soon. When I bring this up, there is always stories of "I did this and nothing happened". This came about when I tack welded 10 studs to a hub. Of these, the heads popped off of 7, 6 months later. I talked with the metallurgist at work and he basically stated it will change the structure every time. A couple of weeks later, I was talking to friend who tack welded the collar on his axels. I finished his sentence by saying "and the axles broke, right?" Which is what had happened. Now, you can weld it, but its not a good idea. I didn't know it at the time, and just wanted to pass this along.
[Re: OUTLAWSSAA]
#2417854
12/13/17 12:05 PM
12/13/17 12:05 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I wouldn't spend a dime w/ Strange. I've seen way more broken Strange parts than I have Moser, not to mention they are hard to deal with. After a lot of asking around, I found the best thing to do was to send axles back to the manufacturer to get redrilled for bigger studs. Moser has great turnaround time and they don't require you to remove the bearing. If you have strange axles, it sounds like you'd be better off to buy new axles from another manufacturer.
[Re: J_BODY]
#2420485
12/18/17 06:24 PM
12/18/17 06:24 PM
72chrgrally
Hamilton,Ont
Well this is just great..... another one of those items I've blindly looked over. Guess I'm adding new axles along with the new rear disc brake. THANKS!! $$$ I hear ya J body!
Photobucket sucks
[Re: J_BODY]
#2429328
01/05/18 04:05 AM
01/05/18 04:05 AM
rowin4
well.... emailed Cass. He gave me contact info at Strange Engineering. Got ahold of them today. Got an RMA and shipped my axles off to them. $80 bucks for the 5/8ths machine work. I have the dual pattern 1/2" studs and it sounds like they will add a third pattern being the 5/8ths. NO they won't add a 3rd bolt pattern. They will re-drill/tap one or both if requested of your existing bolt patterns. Did you request both? did you state which one you wanted?If you do both patterns you have a better choice of wheels , Chevy wheels are always cheeper than Mopar.
[Re: DoctorDiff]
#2429460
01/05/18 03:23 PM
01/05/18 03:23 PM
Triple Threat
Renton Washington
As far as I know, Moser isn't set up to re-drill/tap Strange or Mark Williams "race" axles. Cass, I have a set of your axles in my dana. Would strange or anyone else be able/willing to install 5/8 studs? FYI Your PM box is full.
[Re: J_BODY]
#2429618
01/05/18 08:49 PM
01/05/18 08:49 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
well.... emailed Cass. He gave me contact info at Strange Engineering. Got ahold of them today. Got an RMA and shipped my axles off to them. $80 bucks for the 5/8ths machine work. I have the dual pattern 1/2" studs and it sounds like they will add a third pattern being the 5/8ths. I'll also buy the studs/spacers/lugs from them for some added cost.
I swear looking at my 1/2 studs there was a little bending going on..... Great, who do you contact? I need a set done, maybe two sets.
[Re: Dave Hall]
#2429643
01/05/18 09:59 PM
01/05/18 09:59 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
You'll sleep better too! put it right up there with a billet front drum on a 727.... it might not ever break, but if it does, it's going to do a WHOLE lotta damage! As far as contact info Cass had messaged me an email for Jacob at SE. I emailed them asap on the 2nd and was immediately returned with an auto note that they would be back in the office the 3rd. Checked my phone throughout the day (3rd) and no reply. Got on there web site the morning of the 4th and filled out there online inquiry. Later that day I called and talked with Andrew. Told him what I needed, gave me my RMA number and I shipped my axles out. Later that day the inquiry I emailed was answered, so I simply replied that "Andrew" was taking care of things. I hate to be pushy about these things.... but it was an unforeseen interruption on my disc brake install. I "want" to go racing in about 4 weeks, and I "have" to go racing in March as I'm already preentered in the 60th annual March Meet at Famoso. I tend to drag my feet on stuff and don't need to be addressing this at the last minute. Jay
[Re: Dave Hall]
#2429924
01/06/18 02:11 PM
01/06/18 02:11 PM
dartman366
Mt. Vernon, Ohio
I can't see them taking more than two weeks back to your door. You'll make it. I would say that is a worse case senario, their turn around time is usually pretty quick.. I sent mine in for a shorten and respline and was back in less than that.
[Re: rowin4]
#2436683
01/18/18 02:05 AM
01/18/18 02:05 AM
J_BODY
aZLiViN
well.... emailed Cass. He gave me contact info at Strange Engineering. Got ahold of them today. Got an RMA and shipped my axles off to them. $80 bucks for the 5/8ths machine work. I have the dual pattern 1/2" studs and it sounds like they will add a third pattern being the 5/8ths. NO they won't add a 3rd bolt pattern. They will re-drill/tap one or both if requested of your existing bolt patterns. Did you request both? did you state which one you wanted?If you do both patterns you have a better choice of wheels , Chevy wheels are always cheeper than Mopar. Got the axles back today.... and they did as they stated, added a third pattern for the 5/8 studs. Quick and painless... thanks Strange Engineering! Also purchased their stud kit so it was more than the original 80 bucks.
