Page 2 of 5 < 1 2 3 4 5 >
#2416989 - 12/11/17 06:21 PM Re: Carb suggestions, looking at going Holley [Re: BradH]
ProSport Offline
Loc: Akron, Ohio
Originally Posted By BradH
If you don't use a choke, check out the Holley Days sale on the Quick Fuel "Brawler" 950. Don't freak about them calling it a 950 because the venturi size is only 1.45" vs 1.56" for a 4781. IIRC, the sale price is about $520 right now. It's Quick Fuel's version of the Proform 950, FWIW.
That sounds like the hot ticket for ya Belvedere1.
I would suggest a 950 4150 carb for your combo. If you have the extra money a 950 from Thumper would be the best way to go. If you don't want to go that route you can buy a carb custom built to your combo. The last time I bought a custom Quickfuel from Summit Racing I don't even think there was any extra charge for it money wise. You just fill out a form and they order it, this was several years ago though.
The custom carbs I've used have been spot on, just bolt them on and enjoy your car. The 950 ProSystems carb on my current Duster, I bought it used on Racingjunk. Turns out the thing was only 2 weeks old because his customer wanted efi, and the guy selling it used to work for Prosytems, so he even set it up for my combo, and it runs like perfection. So you can find good deals out there, you just have to hope they haven't messed with the carb much.
Sassy Grass street Duster, best of 10.69 at 124 driven to the track with 3.23 gears, naturally aspirated on 93 octane.
#2417065 - 12/11/17 08:44 PM Re: Carb suggestions, looking at going Holley [Re: ProSport]
Belvedere1 Offline
Loc: Phoenix, AZ
I'll check that Quick Fuel out. They have some great deals going right now through that sale which is what boosted my motivation to look at making a change. I would like to get Thumper's input on either putting one together or tweaking one that I buy.
#2417153 - 12/11/17 11:18 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
ozymaxwedge Offline
Loc: Australia
This add in race parts for sale
Dbl"00"Joe Offline
Loc: N.W. Indiana
Like new 80496-1 Holley 950HP
Has been Tuned by Thumper Carbs
Nice consistent carb only selling to go bigger.
$750
PM me here Thanks
1963 Plymouth Max Wedge
1971 Barracuda
#2417241 - 12/12/17 07:50 AM Re: Carb suggestions, looking at going Holley [Re: ozymaxwedge]
Belvedere1 Offline
Loc: Phoenix, AZ
I saw that one but a little over my budget.
I will be researching the SQ 950 Quick Fuel, the Brawler that Brad mentioned although I am not a fan of the purple throttle plate and metering blocks, and the 0-82591 4150 HP 950.
#2417317 - 12/12/17 10:38 AM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
Thumperdart Offline
Loc: State of confusion
Every carb sent to me even new in the box need work and some more than others. $500 doesn't get ya much imo but try one of those mentioned and see how it works out for ya but I'd at least take it apart and make sure the tech carb matches the carb cos you'd be surprised how many don't........... thumbs
#2417366 - 12/12/17 11:53 AM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
Moparteacher Offline
Loc: Boise
I picked up a refurbished 950xp straight from Holley and saved $200 over Summit, FWIW.
#2417692 - 12/12/17 09:13 PM Re: Carb suggestions, looking at going Holley [Re: Thumperdart]
Belvedere1 Offline
Loc: Phoenix, AZ
Do jets, floats, gaskets, power valves, air bleeds, etc interchange between the Holley and Quick Fuel carbs?
#2417695 - 12/12/17 09:18 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
madscientist Offline
Loc: Washington
Yes.
#2418319 - 12/13/17 11:10 PM Re: Carb suggestions, looking at going Holley [Re: Thumperdart]
Belvedere1 Offline
Loc: Phoenix, AZ
Give me your thoughts on this QFT based SQ-950. I can get this built to my specs but this a starting point.
      It has been assembled with high-flow .110" needle & seat assemblies, 30cc pumps, #33 squirters with pink #330 racing pump cams, non-stick bowl and block gaskets, nylon bowl screw gaskets, and vent baffle. The jetting is 78 up front with a 6.5" Hg high-flow power valve, and 86 in the rear with the power valve circuit blocked. The mounting gaskets are included as shown.
   Here's a list of features;
   QFT polished lightweight aluminum main body with screw-in air bleeds. .073" idle and .030" high speed bleeds installed.
    Red anodized billet aluminum metering blocks that are custom calibrated for maximum performance.
   4 corner idle for fine tuning your idle circuit.
    Teflon coated throttle shafts, stainless steel throttle blades, and loctited button-head screws for increased flow due to decreased turbulence.
#2418488 - 12/14/17 11:42 AM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
Thumperdart Offline
Have them put in .120 cos .110 are not "high flowing" and need more pressure to be stable like 7 psi instead of 6 or less w/the .120`s...........
#2418524 - 12/14/17 01:07 PM Re: Carb suggestions, looking at going Holley [Re: Thumperdart]
BradH Offline
Loc: Valhalla... eventually
I'd want to know what QF uses as an out-of-the-box tune in order to see how much "custom calibration" is really done to a carb built to "your" specs.
Wouldn't be the first time I've heard about "custom calibrated" carbs being about 95% out-of-the-box, and part of the 5% difference includes the decals for the shop that sells it.
Yeah, I'm pretty jaded these days.
#2418533 - 12/14/17 01:34 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
RobR Offline
Loc: Canada
my dad has a couple of new carbs in the box..quickfuel P950 and P1050.he's in the hospital right now and should be home this weekend.maybe drop him a line i know he wants to get them sold
aj
link to pictures
https://imgur.com/a/VcnLb
http://www.youtube.com/watch?v=YilvlLxgv9U
#2418579 - 12/14/17 03:15 PM Re: Carb suggestions, looking at going Holley [Re: BradH]
Thumperdart Offline
YEP.............. drinking
#2418592 - 12/14/17 03:42 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
calrobb2000 Offline
Loc: s. e. pa.
holley list 3916 .
1ts what i use and no issues !
#2418757 - 12/14/17 08:41 PM Re: Carb suggestions, looking at going Holley [Re: BradH]
Belvedere1 Offline
Loc: Phoenix, AZ
It shouldn't be that difficult to compare what is in a box stock SQ-950 to the changes that would be made. I'm still in research mode on the whole thing. I hope to have something figured out in the next couple of days.
#2418774 - 12/14/17 09:15 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
MR_P_BODY Online   content
Loc: Romeo MI
I was very happy with my QTF carb they set up for me..
it was a E-85 carb and they did a fine job.. they asked
a bunch of questions and when I put it on the car it was
on the money even with the AF meter on it.. even the idle
wave
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#2418779 - 12/14/17 09:26 PM Re: Carb suggestions, looking at going Holley [Re: MR_P_BODY]
Belvedere1 Offline
Loc: Phoenix, AZ
Was that buying direct from them?
#2418783 - 12/14/17 09:32 PM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
Loc: Romeo MI
yep.. built for me
wave
CAR IS FOR SALE
#2420746 - 12/18/17 10:18 PM Re: Carb suggestions, looking at going Holley [Re: MR_P_BODY]
Belvedere1 Offline
Loc: Phoenix, AZ
Well I ended up going with a Quick Fuel Street Q 950. I'll report back once I get it on the car and get it dialed in. Thanks to you all and a big thanks to Thumperdart for his guidance.
#2420945 - 12/19/17 11:55 AM Re: Carb suggestions, looking at going Holley [Re: Belvedere1]
Thumperdart Offline
What venturi size is it............When you get it on and running call me if you need some help tuning it in........... callme thumbs
25,489 Registered Members
193,054 Topics
Shoutout to AndyF
by dart4forte
09/23/18 12:30 AM
Chassis dyno cannot be skipped?
by Scott440
09/23/18 12:19 AM
Tough sledding at NMCA Indy
by dvw
09/22/18 11:21 PM
Who sells reproduction owner's manuals???
by Quicksmopars
09/22/18 09:26 PM
