I'm looking to put valve springs on my W-5s
and need spring.. looking for something like
1.55 dia with about 150 on seat and a 2" install
height.. any ideas.. this is for a FT cam so I
am pretty new to them.. also for you guys that
do heads.. how long will the vac hold.. its a new
valve job.. if I put the vac to it and then shut
off the pump how long will it take before the plate
falls off(just a guess) on one it will stay on
for about 25 seconds and another about 12 seconds
thanks
EDIT
Also I'm installing new seals and wonder if you
guys put them in hot water before installing them
thanks again
