Morell hyd roller #2415654
12/09/17 11:15 AM
12/09/17 11:15 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
I dont plan on spinning past 6000
and dont plan on a large lift
Are these a reliable lifter ?
Thanks for any info /experience in advance
Re: Morell hyd roller [Re: sogtx] #2415658
12/09/17 11:32 AM
12/09/17 11:32 AM
crabman173
crabman173
when you us correct preload and spring pressure
1/4 turn preload
open pressure 340 max ( or see Morel site for more details)
they offer higher RPM units but preload and oil weights are critical
Yes that is quality unit
Re: Morell hyd roller [Re: ] #2416155
12/10/17 01:42 PM
12/10/17 01:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
1/4 turn preload
I agree with David, and yes, oil is somewhat critical for these. I have spun them higher than 6,000, BUT, you will need to change the pre load a bit.1/4 turn wont work for every set up.
RIP Monte Smith
Re: Morell hyd roller [Re: CompWedgeEngines] #2416178
12/10/17 02:12 PM
12/10/17 02:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
As I understand it the actual Morel Solid Roller uses the same Hydraulic roller body which are rather long compared to other solid rollers and take shorter pushrods. But functionally they work great and are very durable, and obviosly if they use them for solid applications they are certainly proven at higher than 6000 RPM crank speeds.
If there's any peace of mind remember that 6000 rpm at the crank is proportionally only 3000 RPM at the cam.
I have a nearly new set of Morel SB Mopar solids I only switched them because I wanted to try out the BAM lifters, no difference in performance at all though. I think the only difference is the SB have a V bend in the link bar for valley clearence, I cant think of any reason they wouldn't work in a Big Block.
WIZE
In Car:
Re: Morell hyd roller [Re: Streetwize] #2416234
12/10/17 03:28 PM
12/10/17 03:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I believe Howards uses the Morels and just rebrands them. That is what I use and have well over 4500 street/strip miles on them.
'63 Dodge 330
11.19 @ 121 mph
Re: Morell hyd roller [Re: GY3] #2416271
12/10/17 04:15 PM
12/10/17 04:15 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
thanks Gentlemen !
I feel Better knowing its not like a Comp Cams issue ..
how often would the normal person check
Preload on a street/strip build with rollers ?
Todd - call me !
Re: Morell hyd roller [Re: sogtx] #2416276
12/10/17 04:18 PM
12/10/17 04:18 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I had a Lunati Hyd Roller with their lifters in a street 440. Ran it 3 runs. Best of 13.30 at 4025 lbs with a bad converter.
I ran it to 6000 rpm and it did not go well. After the 3 runs half the adjusters were found to be loose due to valve float.
My 2 cents is be very careful if you run to 6000 rpm. Cover your ground very well. I used 10-40 oil and 10-30 would have been better. There are many variables including how quick the lifter can pump the oil, lifter weight, valve spring pressure, etc.
BTW - Lunati told me the cam and springs could handle 6200 rpm.
Re: Morell hyd roller [Re: markz528] #2416282
12/10/17 04:24 PM
12/10/17 04:24 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
I doubt it will frequently see 6000 past the dyno room
But I guess that means periodic checks
Geesh , should i just go solid ?
Re: Morell hyd roller [Re: sogtx] #2416363
12/10/17 07:00 PM
12/10/17 07:00 PM
crabman173
crabman173
Howards sells lifters from a wide variety of makers
The cheaper hyd rollers from everywhere tend to be Johnsons--Yuck!
Morels basics are best out there for normal use--in Ford and Chevy applications morel offers a lot of part numbers all with very specific requirements for oil weight and max spring pressure and different preloads--all aimed at higher RPM have not checked in a while so they may offer those options in Mopar--Morel has three fine print pages of roller lifter part numbers so when you say Morel that covers a LOT of ground
My experience with hyd rollers in Mopars has been like this
Cranes first lifters were flawless and did anything I asked from the gas pedal NEVER any issues-they quit and Comps were only deal in town--plungers sticking --issues after issue--NO help from Comp ever so --off my list forever
Morels ye haaa!! Follow Morels directions and keep pressures as they require--rev like a chainsaw--no comebacks--RPM way more than you need in street applications ( race cars get solids--period) all good
Other brands can be from anywhere and now more players in the game so hard to tell what you are actually buying unless you consult guys in the know like COMPWEDGE, Marsh , and other top players
me....I am back to Ft hyd's and glad of it no more fuel pushrod issues, expensive distributor gears--all of which are just a PIA for a STREET car so if I need more I just go Solid--
I prefer solids in any real performance application--if your guy does not want to adjust valves--he needs a new Gen3 available at all dealers nationwide just my humble opinion
The other guys on here that build lots of engines and dyno them are the folks to ask -- In the beginning the hyd rollers looked like salvation after all the oil and lobe deals-- but after a few years-- after you actually weigh a pair of Mopar big block hyd rollers and after you see what Crazy stuff Mopar big block hyd rollers can "achieve" on a dyno then you get like me and say uuuhhhh just give me a solid and carry on Builders fight that lifter weight vs how much spring pressure is needed to get safe operation at desired RPM--and all the different lifter valve rates etc It is a tough battle and one I can't see fighting on a street engine
Re: Morell hyd roller [Re: ] #2416403
12/10/17 08:46 PM
12/10/17 08:46 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Thanks Mr crabman
That would be my normal opinion
But . Ive never tried em .. so im gonna give it a whack
Ill just make it a point to check lash , ( i thought i was done with that
Til the next race motor , ugh )
I hope another build can take your advice
Re: Morell hyd roller [Re: sogtx] #2416433
12/10/17 09:55 PM
12/10/17 09:55 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I have used Morals for the past 4 Mopar builds with zero issues. Most of my builds are for street/strip applications so I typically go with somewhat mild roller cams with modern get out of the 80’s beehive springs. up
Re: Morell hyd roller [Re: ] #2416500
12/10/17 11:11 PM
12/10/17 11:11 PM
The Great White North
RAMM Offline
RAMM  Offline
You sure we aint related? All of this ^^^^^^^^^^^^^^^. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Morell hyd roller [Re: RAMM] #2416615
12/11/17 02:22 AM
12/11/17 02:22 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
popcorn
This is great.
Re: Morell hyd roller [Re: ccdave] #2416767
12/11/17 02:24 PM
12/11/17 02:24 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The only Downside to the morels might be (and it's minor) is since the solids use the same long body as their hydraulics, you wind up with a considerably shorter pushrod compared to other brands. On a BB it's not really much of an issue but on something like a wigh winding 340 small block the additional angularity from the 59 degree valley is made a bit more severe when you think of spinning 7K vs 6K. I spun the solids 6800+ in my 414 routinely without issue and when I pulled them out they are "as new"
But they are very high quality and durable from my experience.
WIZE
In Car:
