Door hinge spring replacement?
#2415126
12/08/17 10:41 AM
12/08/17 10:41 AM
Posts: 84 Norway
cudaerik
Norway
I need to replace a borken door hinge spring on my 70 Cuda, Is it possible to do this without removing the door hinge?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Door hinge spring replacement?
[Re: cudaerik]
#2415600
12/09/17 03:30 AM
12/09/17 03:30 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is how it's done while removed and in a vise. If you can duplicate the necessary forces while still attached, it might work.
1. Clamp or hold bottom of spring. 2. With a crescent wrench or similar, turn the top of the spring away from the spring's resting place. 3. Raise spring up and away from resting place (or if in a vise, lower the hinge). 4. Release wrench.
[Re: kentj340]
#2417205
12/12/17 06:10 AM
12/12/17 06:10 AM
Posts: 84 Norway
cudaerik
Norway
Thanks a lot for describing the removal process, I'll give it a try to remove with the door hinge in place.
