Pan gasket #2414925
12/07/17 09:20 PM
12/07/17 09:20 PM
cbusters Offline OP
cbusters  Offline OP
Is the another manufacturer of a paper pan gasket for the Milodon oil pan 31000?
The 40750 Gasket set from Milodon seems to be back ordered everywhere.
Re: Pan gasket [Re: cbusters] #2414941
12/07/17 09:57 PM
12/07/17 09:57 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Pan gasket [Re: cbusters] #2414946
12/07/17 10:11 PM
12/07/17 10:11 PM
cbusters Offline OP
cbusters  Offline OP
I had a new factory windage tray/seal with the new Milodon pan and all the bolts were tight from the machine shop. There was just the assembly oil in the pan and as we were rotating the engine on the stand to clean it for painting, the oil was weeping out of the sides and front of the pan seal. It had sealant on it.
Re: Pan gasket [Re: cbusters] #2415075
12/08/17 02:44 AM
12/08/17 02:44 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It takes a good bead on one edge to button it up, it is still a better setup than a cork gasket. 1,500 miles on mine so far, not a drip.
2020 RAM 1500
Re: Pan gasket [Re: GoodysGotaCuda] #2415077
12/08/17 02:48 AM
12/08/17 02:48 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Worst gasket ever made in the history of gaskets
Re: Pan gasket [Re: sixpackgut] #2415084
12/08/17 03:10 AM
12/08/17 03:10 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Sounds like Ray might have a option on this.
"Just a Bracket car dressed up like a streetcar"
Re: Pan gasket [Re: Just-a-dart] #2415088
12/08/17 03:18 AM
12/08/17 03:18 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
The second the milodon gasket comes out of the packaging a feeling of disgust and guilt overcomes you. I have tried to beg and plead with Superformance to cut some gaskets for us but, come to think of it, I never threatened him. Maybe someone needs to put a little scare in Greg
Re: Pan gasket [Re: cbusters] #2415108
12/08/17 08:43 AM
12/08/17 08:43 AM
cbusters Offline OP
cbusters  Offline OP
Is the Milodon gasket paper or cork?
I have the Milodon Windage tray already on the shelf to convert away from the factory setup.
Re: Pan gasket [Re: cbusters] #2415117
12/08/17 10:15 AM
12/08/17 10:15 AM
Australia
aus370 Offline
aus370  Offline
Australia
Any time you use a cork or paper gasket down there , it will eventually weep oil . I also used the truck tray/gasket with the Milodon pan . A thin bead of sealant especially on the pan sides is good insurance .
My 6.1 is the driest motor i've owned.
Re: Pan gasket [Re: sixpackgut] #2415118
12/08/17 10:20 AM
12/08/17 10:20 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I suppose that I'll need to hear more before I am convinced something that works perfectly fine for me is the worst of it's kind on the Planet...
2020 RAM 1500
Re: Pan gasket [Re: GoodysGotaCuda] #2415133
12/08/17 11:09 AM
12/08/17 11:09 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I think he is referring to the milodon cork gasket?
I used the truck oil pan gasket also with no issues.
Re: Pan gasket [Re: cbusters] #2415168
12/08/17 12:23 PM
12/08/17 12:23 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Dehydrated 18 wheelers tires ground up and mixed with shredded cardboard and held together with elmers glue
