#2414925 - 12/07/17 06:20 PM Pan gasket
cbusters Offline
Loc: Florida
Is the another manufacturer of a paper pan gasket for the Milodon oil pan 31000?
The 40750 Gasket set from Milodon seems to be back ordered everywhere.
#2414941 - 12/07/17 06:57 PM Re: Pan gasket [Re: cbusters]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1
2016 Subaru WRX
#2414946 - 12/07/17 07:11 PM Re: Pan gasket [Re: cbusters]
cbusters Offline
Loc: Florida
I had a new factory windage tray/seal with the new Milodon pan and all the bolts were tight from the machine shop. There was just the assembly oil in the pan and as we were rotating the engine on the stand to clean it for painting, the oil was weeping out of the sides and front of the pan seal. It had sealant on it.
#2415075 - 12/07/17 11:44 PM Re: Pan gasket [Re: cbusters]
5.7L Hemi, 6spd
Loc: Texas
It takes a good bead on one edge to button it up, it is still a better setup than a cork gasket. 1,500 miles on mine so far, not a drip.
2016 BMW X1
2016 Subaru WRX
#2415077 - 12/07/17 11:48 PM Re: Pan gasket [Re: GoodysGotaCuda]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Worst gasket ever made in the history of gaskets
#2415084 - 12/08/17 12:10 AM Re: Pan gasket [Re: sixpackgut]
Just-a-dart Offline
Loc: Glendora Ca.
Sounds like Ray might have a option on this.
"Just a Bracket car dressed up like a streetcar"
#2415088 - 12/08/17 12:18 AM Re: Pan gasket [Re: Just-a-dart]
sixpackgut Offline
Loc: Charleston
The second the milodon gasket comes out of the packaging a feeling of disgust and guilt overcomes you. I have tried to beg and plead with Superformance to cut some gaskets for us but, come to think of it, I never threatened him. Maybe someone needs to put a little scare in Greg
#2415108 - 12/08/17 05:43 AM Re: Pan gasket [Re: cbusters]
cbusters Offline
Loc: Florida
Is the Milodon gasket paper or cork?
I have the Milodon Windage tray already on the shelf to convert away from the factory setup.
#2415117 - 12/08/17 07:15 AM Re: Pan gasket [Re: cbusters]
aus370 Offline
Loc: Australia
Any time you use a cork or paper gasket down there , it will eventually weep oil . I also used the truck tray/gasket with the Milodon pan . A thin bead of sealant especially on the pan sides is good insurance .
My 6.1 is the driest motor i've owned.
#2415118 - 12/08/17 07:20 AM Re: Pan gasket [Re: sixpackgut]
5.7L Hemi, 6spd
Loc: Texas
I suppose that I'll need to hear more before I am convinced something that works perfectly fine for me is the worst of it's kind on the Planet...
2016 BMW X1
2016 Subaru WRX
#2415133 - 12/08/17 08:09 AM Re: Pan gasket [Re: GoodysGotaCuda]
RTSE4ME Online   confused
Loc: MD
I think he is referring to the milodon cork gasket?
I used the truck oil pan gasket also with no issues.
#2415168 - 12/08/17 09:23 AM Re: Pan gasket [Re: cbusters]
sixpackgut Offline
Loc: Charleston
Dehydrated 18 wheelers tires ground up and mixed with shredded cardboard and held together with elmers glue
25,067 Registered Members
185,577 Topics
Ignition timing over heating?
by da50r
01/16/18 04:04 PM
Exhaust leak ??
by Jupiter331
01/16/18 03:30 PM
INDY 440-3RB VS INDY 440-2RB WITH 440-2A 2" RISER
by moparjohn
01/16/18 03:01 PM
M Code Lug Nuts
by hemiviper588
01/16/18 03:01 PM
