Re: Pan gasket
[Re: cbusters]
#2415075
12/08/17 02:44 AM
12/08/17 02:44 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I had a new factory windage tray/seal with the new Milodon pan and all the bolts were tight from the machine shop. There was just the assembly oil in the pan and as we were rotating the engine on the stand to clean it for painting, the oil was weeping out of the sides and front of the pan seal. It had sealant on it. It takes a good bead on one edge to button it up, it is still a better setup than a cork gasket. 1,500 miles on mine so far, not a drip.
Re: Pan gasket
[Re: GoodysGotaCuda]
#2415077
12/08/17 02:48 AM
12/08/17 02:48 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine. Worst gasket ever made in the history of gaskets
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Pan gasket
[Re: sixpackgut]
#2415084
12/08/17 03:10 AM
12/08/17 03:10 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine. Worst gasket ever made in the history of gaskets Sounds like Ray might have a option on this.
"Just a Bracket car dressed up like a streetcar"
Re: Pan gasket
[Re: Just-a-dart]
#2415088
12/08/17 03:18 AM
12/08/17 03:18 AM
sixpackgut
Charleston
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine. Worst gasket ever made in the history of gaskets Sounds like Ray might have a option on this. The second the milodon gasket comes out of the packaging a feeling of disgust and guilt overcomes you. I have tried to beg and plead with Superformance to cut some gaskets for us but, come to think of it, I never threatened him. Maybe someone needs to put a little scare in Greg
Re: Pan gasket
[Re: cbusters]
#2415117
12/08/17 10:15 AM
12/08/17 10:15 AM
Posts: 80 Australia
aus370
Australia
Any time you use a cork or paper gasket down there , it will eventually weep oil . I also used the truck tray/gasket with the Milodon pan . A thin bead of sealant especially on the pan sides is good insurance . My 6.1 is the driest motor i've owned.
Re: Pan gasket
[Re: sixpackgut]
#2415118
12/08/17 10:20 AM
12/08/17 10:20 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine. Worst gasket ever made in the history of gaskets I suppose that I'll need to hear more before I am convinced something that works perfectly fine for me is the worst of it's kind on the Planet...
Re: Pan gasket
#2415133
12/08/17 11:09 AM
12/08/17 11:09 AM
Posts: 2,033 MD
RTSE4ME
MD
I just use the truck oil pan gasket and RTV the one corner on my milodon pan. There's no way i'll put a cork/Milodon gasket on a modern engine. Worst gasket ever made in the history of gaskets I suppose that I'll need to hear more before I am convinced something that works perfectly fine for me is the worst of it's kind on the Planet... I think he is referring to the milodon cork gasket? I used the truck oil pan gasket also with no issues.
Re: Pan gasket
[Re: cbusters]
#2415168
12/08/17 12:23 PM
12/08/17 12:23 PM
sixpackgut
Charleston
Is the Milodon gasket paper or cork? I have the Milodon Windage tray already on the shelf to convert away from the factory setup. Dehydrated 18 wheelers tires ground up and mixed with shredded cardboard and held together with elmers glue
