W2 stroker build: header primary tube size
#2414845
12/07/17 06:54 PM
12/07/17 06:54 PM
Posts: 1,754 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Looking for recommendations regarding the size of the header primary tube.
Intended use is (M-body in the sig, 3600 lbs race weight): weekend driver, not a drag racer, a typical street/light-strip car. W2 based 408 stroker, forged crank, H-beam rods, 10.5:1 CR, hydraulic roller cam, 6500 max RPM, 4k converter, 4.10 rear end ratio.
I am moving to the TTI headers, specifically looking at the 340W2 (1-5/8" primary) or 340W2-17835 (1-7/8" primary) setups.
Previously I have only ran 1-5/8" tubes, always on a stock displacement motor (360"), these worked well on the car. The remainder of the exhaust are dual 3" pipes with X-pipe, all feeding into Hooker MaxFlow mufflers.
Given the move to a stroker (408) and the cost of these headers in particular, I am wondering whether I should be looking at the 1-7/8" tubes in order to get some "room to grow"?
While I always aim for max-performance effort within a particular combo, this is not a motor that will spend a lot of time in the upper RPM, it simply is not a drag race vehicle.
My original thinking was to stay with the 1-5/8 tubes, but given the extra cubic inches that the stroker brings, the fact that at WOT I push the converter to the 4k stall and with the 4.10 gears it'll buzz real quick I am now wondering what the best option is. What do you recommend?
Re: W2 stroker build: header primary tube size
[Re: Diplomat360]
#2414850
12/07/17 07:04 PM
12/07/17 07:04 PM
Posts: 4,457 Washington
madscientist
Washington
I run 1.875 tubes on a 340 CID street car.
That would be the minimum size I would run.
[Re: Diplomat360]
#2414951
12/07/17 10:29 PM
12/07/17 10:29 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For comparison, when I was testing my 383....... Unported 906's, rpm intake, solid cam....... Going from 1-3/4 x 3 headers up to 1-7/8 x 3 headers picked up power pretty much everywhere(within the tested range). More tq and more hp.
I don't recall the amount off the top of my head..... Around 15hp iirc...... On a motor smaller than what you're building, and with much lesser flowing heads.
The info is in the tech archives if you're curious.
[Re: Diplomat360]
#2415026
12/08/17 12:37 AM
12/08/17 12:37 AM
Diplomat360
Windsor, ON, Canada
Well, sort of late to the game with this info, but I did call TTI when I got some free time to get their recommendation. The gentlemen I spoke with literally said: "...if over 600 hp then use 1-7/8" pipe...". Even when I asked him for the "room to grow", it all came down to that seemingly magic 600hp mark. Alright, a bit weird I think, because as I've been scouring the net tonight trying a learn a bit more about this, I am universally seeing that 600 level being more of a 500 mark. Again, these are just numerous posts from folks like you and I. I did come across a decent Header Ho-Down article, where 4 different sized pipes were compared. Even on a smaller displacement engine (that was a Chevy 383) it appears the big 1-7/8" primary pipes posted some impressive dyno numbers throughout the combo powerband. So seemingly counter-intuitive to the "smaller primary pipe nets more torque". How is the clearance with the 1-7/8" header install on a SB look like?
[Re: Diplomat360]
#2415031
12/08/17 01:01 AM
12/08/17 01:01 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
I have 1 7/8 TTI W2 headers on an Abody. They fit tight but they fit great. The one thing the instructions lack is they only tell you to jack the car up. They do not tell you that you need to jack the car up really really really high, but do that and they go right in.
68 Barracuda Formula S 340
[Re: Diplomat360]
#2415035
12/08/17 01:11 AM
12/08/17 01:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
With 1 7/8 you shouldnt have any problems.. you might want to run 1 7/8 but with a 3.5" collector.. will make more torque.. I'm running 1 7/8 with a 3.5" collector on my 416... It does go back down to a 3" after the collector but I also run electric dumps right after the collector to help reduce back pressure EDIT this is with a full exhaust out to the bumper
[Re: Diplomat360]
#2415045
12/08/17 01:25 AM
12/08/17 01:25 AM
madscientist
Washington
I agree on the 3.5 inch collector. I forgot to mention that.
I would also make sure you have 18 inches of collector. Maybe a bit more.
[Re: Diplomat360]
#2415150
12/08/17 11:40 AM
12/08/17 11:40 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I have to agree with the 1 7/8 with a 3 1/5 collector. I'm currently running a 2" tube with a 4" collector on my 408.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: gregsdart]
#2415207
12/08/17 01:38 PM
12/08/17 01:38 PM
madscientist
Washington
Just thinking, how would step 1 3/4 to 1 7/8 work? I know 1 5/8 to 1 3/4 work very well on a 500 hp 408 build. I've never seen a step header make more power than a straight header if the straight header was correct.
[Re: Diplomat360]
#2415211
12/08/17 01:41 PM
12/08/17 01:41 PM
fast68plymouth
So. Burlington, Vt.
I don't feel the 3.5 collector is the right set-up for the OP's combo.
Ideally, I would want 1-3/4 > 1-7/8 stepped primaries with a 3" collector for that combo if I had the choice.
IMO, the 1-5/8 primaries and w2 heads doesn't make any sense.......well...... Maybe on a 318.
[Re: madscientist]
#2415231
12/08/17 02:17 PM
12/08/17 02:17 PM
MR_P_BODY
I have tested a 1 3/4-1 7/8 step header on my W-9.. it made more low end torque.. then I went to a 3 step.. 1 3/4-1 7/8- 2.00.. still had the low end torque and better on top end.. I ended up building the 3 step
[Re: madscientist]
#2415661
12/09/17 11:49 AM
12/09/17 11:49 AM
Posts: 2,578 sweden
1Fast340
sweden
Just thinking, how would step 1 3/4 to 1 7/8 work? I know 1 5/8 to 1 3/4 work very well on a 500 hp 408 build. I've never seen a step header make more power than a straight header if the straight header was correct. Take a look at the prostock and nascar guys anytime you want,they do and pay anything to make that last fraction of a hp.
[Re: Diplomat360]
#2415675
12/09/17 12:28 PM
12/09/17 12:28 PM
Posts: 250 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
no fitment problems with 1-7/8'' TTI's. that's what i run with zero issues.
go with the 1-7/8'' and never look back
[Re: 340Cuda]
#2415904
12/09/17 09:25 PM
12/09/17 09:25 PM
Posts: 9,870 Weddington, N.C.
Streetwize
Weddington, N.C.
I don't know about primary tube but if the collector is too small (where it doesnt allow the motor to achieve it's natural torque peak RPM) it will limit top end power....(so to me) that could likely be more than 5% of the potential peak power. Stahl was also likely talking about an open header/race situation which is obviously very different from a street/strip type application. In other words the peak torque limit of a too small collector could very likely lower the HP trajectory/rate of rise/curve from that RPM all the way to peak....that being said.... (cont'd below)
