#2403895 - 11/15/17 08:24 AM '04 5.7 with '09-up heads?
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
I have a friend w/ a 2004 5.7 hemi that dropped a valve seat and chewed a cylinder.
He's looking to get a replacement motor, but doesn't want to run into this issue again. I know the early hemis are known to drop seats, but apparently they fixed this issue in the 2009 models?
What is involved in using the '09-up heads on the earlier motor? I've been told I'd need to get the valve covers and coil packs for the newer heads. Any other differences?
How much does the compression increase doing this swap?
Would it be easier (or even possible) to use the complete 2009-up motor in the older vehicle?
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2403977 - 11/15/17 11:46 AM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
RTSE4ME Offline
Loc: MD
You'll also need pushrods, and intake manifold.
compression 12-12.5 on a stock piston 5.7
#2404077 - 11/15/17 03:05 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
OK, so the compression makes this swap not feasible for a daily driver w/ no other mods.
Anyone know if the newer motor is a drop in for the old one?
Or just get another old style motor and hope the seats stay put?
CHIP
#2404142 - 11/15/17 04:37 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
HotRodDave Offline
Loc: Kalispell Mt.
I have worked on a bunch of these engines and never seen a seat drop unless it overheated first.
The later heads bolt on with pushrods being the minimum extra parts needed. The intake and ex manifolds are good to do at the same time.
I came up with 11.5 when I actually CCd everything I had sitting here. That is only a little more than an apache 392 so I think it could live on premium. You can try thicker head gaskets but in my experiance and many others the higher quench distance is more likely to cause detonation than the higher static compression. The late hemi chamber is very detonation resistant and the plastic intakes keep a lot of heat out of the air charge. All this adds up to a very compression tolerant design. The extra compression will improve MPG some and help offset the cost of premium though probably not the entire cost difference. You could upgrade to a 6.1 cam and also bleed off a little compression for cheap as well as help hp.
The short block is diffent enough to make swapping the short block not worth it, the VVT uses a different timing cover and will make some headaches in the swap.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2404208 - 11/15/17 06:36 PM Re: '04 5.7 with '09-up heads? [Re: HotRodDave]
WO23Coronet Offline
Loc: Canada
What if you used a complete Eagle engine for the respective chassis (LX for LX, truck for truck)? The LX looks like it would be a drop in physically. You'd have to lock out the cam. What about the sensors? Are they the same/able to be swapped over?
I have a DD 05 Magnum RT that I would like to play with when it's DD duties are done. Pondered the Eagle head swap but by the time you're done buying the parts, you aren't far off from a complete Eagle engine
#2404276 - 11/15/17 08:30 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
HotRodDave Offline
Loc: Kalispell Mt.
locking the cam is super simple and no special parts or kit needed. I don't know if the cam phaser will fit behind the earlier timing cover.
#2404614 - 11/16/17 05:45 PM Re: '04 5.7 with '09-up heads? [Re: HotRodDave]
ric3xrt Offline
Loc: Trumbauersville PA
The early cover doesn't work on the vvt engines, phaser hit the cover and the sensor will be in the wrong spot
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2405167 - 11/17/17 05:30 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
WO23Coronet Offline
Loc: Canada
I’m talking a complete engine swap, a complete Eagle engine, you’d use the Eagle front cover and accessories. Lock the cam and swap over the necessary sensors but use all the Eagle stuff you can
Edited by WO23Coronet (11/17/17 06:00 PM)
#2405782 - 11/18/17 11:32 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
RTSrunner Offline
Loc: Pittsburgh,PA
Doesn't the tone ring have a different tooth count on the later engine vs the early gen3? Requiring the crank to be pulled to change.
#2407103 - 11/21/17 08:23 PM Re: '04 5.7 with '09-up heads? [Re: RTSrunner]
GoForBroke Offline
Loc: Mid West US
Correct 03-08 5.7 have a 32 tooth and 09-up have a 58 tooth. They cant be swapped out without rebalancing the crank either. It's not an easy swap I believe the accessories have been moved a little so your alternator, AC compressor, etc.. won't line up.
#2407256 - 11/22/17 07:28 AM Re: '04 5.7 with '09-up heads? [Re: WO23Coronet]
ric3xrt Offline
I can't speak for the Eagle 5.7 but, the 6.4 BGE truck Apache. we have one running in a 06 magnum, pulled the crank swapped a 6.1 32 tooth ring on it, new bearings, locked the cam and away it went,(after some tuning,) Car had Air condition and Power steering removed,only accessory is the Alternator (power rack replaced with a Flaming river custom unit), car has about 22k on it after the swap. Still has the Apache front cover on it.
#2407297 - 11/22/17 09:02 AM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
GoForBroke Offline
Loc: Mid West US
No vibrations I'm assuming. The 32 tooth wheel weighs 121 grams more than the 58 tooth.
#2407501 - 11/22/17 03:32 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
ric3xrt Offline
Runs smooth, maybe it's the 4 bolt vs 3 bolt, Maybe 4 Bolt distributes the extra weight more evenly than the 5.7s..Not sure what to say...runs fine.
2003 Ram st
2004 Rumble Bee
#2407549 - 11/22/17 05:33 PM Re: '04 5.7 with '09-up heads? [Re: an8sec70cuda]
HotRodDave Offline
Loc: Kalispell Mt.
on both tone wheels the weight is distributed pretty evenly so its not going to make a difference that one is heavier than the other.
#2414769 - 12/07/17 01:34 PM Re: '04 5.7 with '09-up heads? [Re: HotRodDave]
Tom_440 Offline
Loc: Las Vegas, NV
When my '05 5.7 dropped a valve seat, I spoke with a local machine shop. The owner says they do a lot of these and simply "stake" the seats and they don't drop again.
#2414848 - 12/07/17 03:57 PM Re: '04 5.7 with '09-up heads? [Re: Tom_440]
HotRodDave Offline
Loc: Kalispell Mt.
sounds hokey to me, especially since every one I have seen with a dropped seat the head was all tore up and the recess where the seat fell out would no longer even fit snug with a new seat in it. When a brand new head is like $500 why bother with all that?
25,343 Registered Members
190,186 Topics
Most users ever online: 1,417 @ 06/18/18 08:39 PM
How do I test a ballast resistor?
by rickseeman
35 minutes 11 seconds ago
Mopars at the Park Fox Lake, ILLINOIS this Sunday!
by Rhinodart
Today at 11:50 AM
monkeys toy
by azmopar
Today at 11:48 AM
How to identify this old Hemi!
by RUMBLON
Today at 11:18 AM
