Page 2 of 2 < 1 2
#2414590 - 12/07/17 06:48 AM Re: VVT cam journal size . [Re: aus370]
aus370 Offline
Loc: Australia
Big thanks ric3xrt , steff for clearing this up .
I carefully read through a few times - Convinced me , there's possable work arounds , but just not worth it .
Stock 6.1 Hemi . 11.657 @ 113.54 , 3588 lbs.
Sweet on the street , a bit dull on the track .
#2414591 - 12/07/17 06:53 AM Re: VVT cam journal size . [Re: STEFF]
aus370 Offline
Loc: Australia
Originally Posted By STEFF
It's totally different between VVT and non-VVT, like shown above. The best way to handle it is to pony up and spend the money on a custom cam core....$1000 ball park. I made an adapter like shown above from Nutter Racing and it's hanging on my wall. Do not like it at all, just hanging off the front. I looked at making an adapter that would include the whole journal instead of just the front only but the wall thickness of the adapter would be too thin in that it would probably crack when being heat treated or being pressed on to the cam.
Again, the best way to remedy this if you are going to use a VVT block and not use the VVT features, is to have a custom core made. That's what I did.
Unfortunately, the current cores available for the VVT blocks are only capable of handling cam specs that are compatible for use with the VVT and computer features.
Who does these custom vvt cam cores.
#2414592 - 12/07/17 06:57 AM Re: VVT cam journal size . [Re: aus370]
fbs63 Offline
Loc: NW Indiana
LSM
#2414728 - 12/07/17 12:21 PM Re: VVT cam journal size . [Re: aus370]
cudadoug Offline
Loc: Between a rock & a hard place
So, is there any way to use a VVT cam in VVT block, but lock out the function? Just curious...
#2414732 - 12/07/17 12:23 PM Re: VVT cam journal size . [Re: cudadoug]
STEFF Offline
Loc: Smyrna, South Carolina
Yes, Comp has a VVT Lock kit.
#2414749 - 12/07/17 12:55 PM Re: VVT cam journal size . [Re: aus370]
WO23Coronet Offline
Loc: Canada
Would it be possible (or has anyone tried) to manually control the solenoid so you can set your ICL on the fly? Advance it for bottom end and retard it for top end? (Or whatever works best for your combo)
Edited by WO23Coronet (12/07/17 12:55 PM)
#2414844 - 12/07/17 03:47 PM Re: VVT cam journal size . [Re: aus370]
Bad340fish Offline
Loc: Tulsa OK
With a large cam piston to valve clearance might be a problem. I believe the Megasquirt 3 goldbox platform supports VVT for the G3. I know megasquirt is capable of VVT control on lots of other cars.
68 Barracuda Formula S 340
Page 2 of 2 < 1 2
25,382 Registered Members
190,870 Topics
fender emblems
by btomasko
6 minutes 6 seconds ago
New manual steering box
by Fishmarket
8 minutes 43 seconds ago
The case of the missing playground set !
by bigdad
27 minutes 9 seconds ago
Borgeson Earns High Praise From Customers
by Rustymuscle
Today at 07:29 AM
