Page 1 of 2 1 2 >
#2379627 - 09/30/17 09:51 PM Wanted - Big Block Engine - 4th Quarter
moparts Offline
#2380026 - 10/01/17 02:27 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
dart4forte Offline
Loc: Mesa, Arizona
Looking for a cast iron big block water pump housing with lower hose to the driver side.
#2381803 - 10/04/17 12:39 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
NachoRT74 Offline
Loc: Caracas, Venezuela, SouthAmeri...
WTB KB215 +20 piston left side exhaust ( 5th cylinder ), old kind design exhaust with asymetric valve pockets
#2382385 - 10/05/17 11:19 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
philb Offline
Loc: pa
Wanted EDELBROCK ALUMINUM INTAKES, THESE NUMBERS
1. CH4B--440 CI
2. DP4B--383 CI
3. LD340--SMALL BLOCK
4. LD4B---SMALL BLOCK
PHONE--570-923-1416
570-923-0176
PHIL BALDACCHINO
#2382494 - 10/05/17 02:00 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
carter Offline
Loc: sweden
Looking for a Clay Smith mech fuel pump to BB.
I have PayPal and a shipping address in FL
#2382751 - 10/05/17 09:28 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: carter]
BigHemiVegas Offline
Loc: Where else?
I am wanting to buy a Weiand 6 pack tunnel ram for a 440. Let me know if you have one for sale. Please send me a PM and Thanks!
#2383548 - 10/07/17 05:56 PM Re: Wanted -1962,,,, 413 max wedge pistons [Re: moparts]
philb Offline
Loc: pa
WANTED--1962 413 MAX WEDGE PISTONS, NEW OR USED, .030 OR .060
OVER, LET ME KNOW BRAND NAME, ANY INFO ON PISTONS, PRICE
PHIL B.
PHONE--570-923-1416
570-923-0178
#2385844 - 10/11/17 06:03 PM Re: Wanted -1962,,,, 413 max wedge pistons [Re: moparts]
moparhotrods Offline
Loc: New Castle,DELAWARE
wanted
a nice set of 383.040 over forged pistons if you have such a set please PM me here on the board and include a phone number thank you
#2387653 - 10/15/17 09:17 AM Re: Wanted - Big Block 400 [Re: moparts]
mrpatel Offline
Loc: Niagara, Ontario Canada
Looking for a 230 casting that has been sonic checked. Andrew
#2388402 - 10/16/17 07:38 PM 1970 6 pack 4 speed carbs wanted [Re: mrpatel]
ogopogo Offline
Loc: BC Canada
looking for a set of correct 6bbl carbs for a 1970 charger 4 speed
ogopogo69 at shaw.ca
#2390769 - 10/21/17 10:27 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
440mopar Offline
Loc: USA
I am looking for a pit-free big block cast crank two groove pulley for my 1972 400. It had a four groove pulley on it as the car had AC which I have removed. I would like a pulley that is specifically for a cast crank so that it has the proper bolt hole spacing.
Also a 383-400 high rise throttle bracket kit.
I am also looking for the following 1967 440 engine parts:
Carter AFB carb. #4327S
Distributor #2642748 or #2642822
Fan clutch #2806070
fourfortymopar at yahoo.com
Edited by 440mopar (11/10/17 07:30 PM)
#2392814 - 10/25/17 08:41 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
CoDart Offline
Loc: Fort Collins, Colorado
Looking for 20 or 30 thou over 383 flat top or dished pistons. Thanks!
#2393679 - 10/27/17 02:06 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: CoDart]
tobnHisglory Offline
Loc: Chester, VA
Found it. Thanks Brad H.!
Thanks and God bless!
Edited by tobnHisglory (10/27/17 02:00 PM)
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
#2399880 - 11/07/17 08:36 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
Max Weg Offline
Loc: Canada
Wanted Mopar Performance P5007494 Max Wedge Heads. Let me know what you have.
Max Weg
#2402000 - 11/11/17 02:02 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
dart4forte Offline
Loc: Mesa, Arizona
Looking for 68-69 factory cast iron manifolds for a 68 Dart GTS with a bigblock. Numbers are 2863900 or the 67 2899002
#2402111 - 11/11/17 05:20 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: dart4forte]
birdtracker Offline
looking for 4.380 stroker pistons for a 472 low deck. PM here. thanks Birdtracker
#2403928 - 11/15/17 09:40 AM '68 Carter AVS part needed [Re: moparts]
bboogieart Offline
Loc: Lost and Spaced
I am reworking a 68 Carb. as stated.
The small tube poking out the front in the base is missing.
I believe it is for the hose connecting to the PVC valve.
Anyone have one or know where I might find one?
Thanx.
Question asked and answered in the general section.
Walker part# 17-100
Thanx Supercuda up
https://carburetion.walkerproducts.com/carter/carter-carburetor-kit-4bbl-afb-avs/
I have mechanical Aptitude.
I can screw up anything.
#2404293 - 11/15/17 08:59 PM Re: Wanted - Big Block Oil Pan For '62-'65 B-Body [Re: moparts]
VANDAN Offline
Loc: WESTERN NEW YORK
Looking for a 5qt+1 oil pan to fit a Big Block '62-'65 K-member. These would have been used on The Max & Street Wedge, and the 383 HP Factory builds. Will consider all options, but trying to keep a stock appearance, and as much road clearance as possible. Thanks for any input.
#2404411 - 11/16/17 07:02 AM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
Mag162 Offline
Loc: Long Island New York
Looking to convert my 67 383 2bbl to a 4bbl
Looking for an Intake
#2405969 - 11/19/17 01:17 PM Re: Wanted - Big Block Engine - 4th Quarter [Re: moparts]
mopowers Offline
Loc: Sac, CA
I'm looking for a good useable secondary fuel bowl for a Holley 4150 double pumper. Must have good threads for everything.
PM me a price shipped to 95691.
Thanks!
Page 1 of 2 1 2 >
25,073 Registered Members
185,627 Topics
67 GTX production numbers
by 440mopar
01/18/18 11:51 PM
Want aluminum wheels, 2006 Mega.. 17, 18, 20 ????
by sunroofgtx
01/18/18 10:58 PM
Ugly finish to the day....
by Satilite73
01/18/18 10:47 PM
Longtime Ohio CPD Dealer Albert Weekley passed away.
by 300by500
01/18/18 10:14 PM
