Re: 413 Motorhome
[Re: scannman70]
#2414773
12/07/17 04:43 PM
12/07/17 04:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Still a good motor to build?
I don't think they were ever a good motor to build for anything other than HD use, as designed.
The block, and maybe crank and rods are ok if you really want a small bore RB.
Other than the the rest is scrap. If someone gave it to you that would be a fair price, assuming they'd already pulled it too.
Re: 413 Motorhome
[Re: Supercuda]
#2414811
12/07/17 05:53 PM
12/07/17 05:53 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
If memory serves, the heads are unique and have little to no value. The exhaust manifolds were prone to cracking, so good ones have some value if you can find the right buyer. See them on eBay.
Pistons were dished for low compression. Water pump setup is unique too, of no value. Oil pan of no value and limited applicability in my experience.
A good strong block with thick cylinder walls, typically can be bored out up to .120" for a 426 displacement bore. Good crankshaft and pretty standard connecting rods. I've seen 6 and 8 bolt crank flanges on them.
That said, I've one painted up on a stand in the pole barn. Put closed chamber heads on it and plan to use it for street use to move a station wagon around. Mine only had 45K miles on it. I paid $200 for mine several years back and was happy to pay that as good as it looked inside. I viewed it as a $200 short block in good condition.
Lead, follow or get the hell out of the way
Re: 413 Motorhome
[Re: scannman70]
#2414846
12/07/17 06:55 PM
12/07/17 06:55 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Its a good starting point. However, as has been said the only thing from a performance standpoint on the "motorhome" version that's of any real use is the short block. Take that and add a good set of heads and better pistons and it can be a very respectable power maker.
Also, you only need to enlarge a 413s 4.18 bore +.70 to get to the 4.25 bore of the 426 wedge.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
Re: 413 Motorhome
[Re: scannman70]
#2414851
12/07/17 07:04 PM
12/07/17 07:04 PM
Supercuda
About to go away
About to go away
up yours
Pistons are low compression scrap and finding useful non-low compression off the shelf 413 pistons or 426 WEDGE pistons is tough. Sure you can pay to have custom pistons though $$$.
I sure wouldn't pay money for it.
Re: 413 Motorhome
[Re: scannman70]
#2415022
12/08/17 12:30 AM
12/08/17 12:30 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
I've used those blocks on several motors I've built to replace the 426 W blocks that where wore out. I have one in the shop now that I sonic tested last week, I will bore it from stock(4.170 or maybe there 4.180 stock ) to 4.250 and use a Mopar 4.150 stroke crank with stock Mopar rod journals and a set of Eagle 6.800 long Mopar H beam steel rods with a set of custom pistons to make a pump gas motor for my 1963 Plymouth Fury It sonic tested okay, it won't go much above 4.25 safely though I had the stock steel crankshaft offset ground down to 2.200 and increased the stroke to 3.910 for a 440 motorhome motor I have to make another 464 C.I. pump gas stroker with aluminum heads to sell
Re: 413 Motorhome
[Re: scannman70]
#2415158
12/08/17 12:09 PM
12/08/17 12:09 PM
Supercuda
About to go away
About to go away
up yours
Efficient? No it was not designed to be efficient
Durability was it's major feature.
Re: 413 Motorhome
[Re: Centerline]
#2415377
12/08/17 07:47 PM
12/08/17 07:47 PM
peabodyracing
Minnesota
Also, you only need to enlarge a 413s 4.18 bore +.70 to get to the 4.25 bore of the 426 wedge. Thanks for clarifying my error on over bore. I was going on 45+ year old engine work I'd had done, plus tired brain cells. As has been mentioned, they work good to replace 426W blocks, which were getting scarce even back then. My current 426W is a 413 block I'd bored to 426. It's certainly seen its' share of abuse over the years and hasn't failed me yet.
Re: 413 Motorhome
[Re: scannman70]
#2415382
12/08/17 07:55 PM
12/08/17 07:55 PM
Supercuda
About to go away
About to go away
up yours
My 64 300 came with a 413. I rebuilt it, put on 906 heads, added the Street Hemi grind cam, a 750 and 4.10 gears out back. It scooted well enough.
But it didn't start as a MH 413.
Re: 413 Motorhome
[Re: scannman70]
#2415652
12/09/17 11:11 AM
12/09/17 11:11 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
What kind of specs do factory industrial 413 camshafts have ?
From allpar
Quote Just in 1969, the big block V8s had around sixty variations. There were 413s with two-barrel carburetors, for school buses and dump trucks. There were six blocks, five cylinder-head variations, four camshafts, three timing chains, four flywheels, four torque converters, five different oil pans, and many different linkage brackets End quote
Re: 413 Motorhome
[Re: peabodyracing]
#2415696
12/09/17 01:06 PM
12/09/17 01:06 PM
Centerline
Texas Hill Country
Also, you only need to enlarge a 413s 4.18 bore +.70 to get to the 4.25 bore of the 426 wedge. Thanks for clarifying my error on over bore. I was going on 45+ year old engine work I'd had done, plus tired brain cells. As has been mentioned, they work good to replace 426W blocks, which were getting scarce even back then. My current 426W is a 413 block I'd bored to 426. It's certainly seen its' share of abuse over the years and hasn't failed me yet. I originally wanted to do that on my Polara but couldn't find a 413 block at the time. Wound up with a 440 instead.
