#2412224 - 12/02/17 10:42 AM Will this rim and tire Combo fit my Charger?
70RT Charger Offline
Loc: eastern,Ky
All 4 rims are an US Mag Bandit 109 18x9
Bolt Pattern: 5x4.5
Offset: 8
Backspacing: 5.25
Bore 72.60
Rear Tires: Nittos 295x45x18
Front Tires: Nittos 255x45x18
Mostly all stock Suspenion but has been lowered 2" in the back
Thanks!
#2412324 - 12/02/17 03:35 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: Covina, Ca
What rear end do you have? What suspension are you running? Do you have any fancy control/strut arms/bushings? Brakes? What year Charger? All are details that are going to help us, help you.
The easiest method is to take some cardboard, and make a mock up wheel and measure. Compare your current wheel and tire setup to your new wheel and tire setup with this site: https://rimsntires.com/specspro.jsp
68 Dart GT Project Thread: Linky!
#2413116 - 12/04/17 12:54 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
astjp2 Offline
Loc: Utah and Alaska
I will run square 295 nitto's on my 68 when I get it up and running
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
#2413689 - 12/05/17 02:47 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
Sweet5ltr Offline
Loc: Florida
Bolt Pattern: 5x4.5
Offset: 8
Backspacing: 5.25
Bore 72.60
Thanks!
I run the exact same Nitto tire sizes on my 69' Road Runner. Stock style suspension, upgraded (Hotchkis). Tires will rub the sway bar under full-lock. I run a bit more modern wheel, clears Dr. Diff Brembo style calipers. You should be slightly ahead with less backspacing I would imagine, as I run .200" spacers front & .375" spacers rear.
Fronts -
Offset: +1.4"
Backspacing: 6.38"
Weight: 23 lbs
Rears -
Offset: +0.9"
Backspacing: 6.36"
Weight: 25 lbs
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
#2414119 - 12/06/17 09:16 AM Re: Will this rim and tire Combo fit my Charger? [Re: Sweet5ltr]
Loc: eastern,Ky
Bolt Pattern: 5x4.5
Offset: 8
Backspacing: 5.25
Bore 72.60
Thanks!
Fronts -
Offset: +1.4"
Backspacing: 6.38"
Weight: 23 lbs
Rears -
Offset: +0.9"
Backspacing: 6.36"
Weight: 25 lbs
I’m be running all stock suspension as of now with 2” lowering blocks in the back but I do plan on upgrading my suspension and brakes next year. So you’re thinking I should be good?
#2414340 - 12/06/17 04:12 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
Sweet5ltr Offline
Loc: Florida
68-70 b-body wheel well design should be similar, but i'm not an expert, there may be slight differences between makes and models. I would like to say 'yes, you're good' but even different brands of brake kits / rotors can add or remove track width. I'm running Baer rear discs (Cobra) and a dr. diff stage IV kit on the front.
All I can say is this wheel backspacing works on my b-body and an a-body application as well.
Here is a chart that may help you! May be beneficial to grab a few measurements before you order like others have stated.
I would be sure to give US Mag a call to verify if that specific wheel will allow proper brake caliper clearance with the kit you plan on purchasing in the future.
#2414466 - 12/06/17 08:21 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
Loc: eastern,Ky
Ok thanks a lot!
#2414521 - 12/06/17 10:06 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
This is with an 18x9 front (4.75 BS), 275-40-18.
Rear is an 18x10 also 4.75 BS, 295-45-18.
#2414523 - 12/06/17 10:10 PM Re: Will this rim and tire Combo fit my Charger? [Re: 70RT Charger]
Loc: Granite Bay CA
More
#2414673 - 12/07/17 10:38 AM Re: Will this rim and tire Combo fit my Charger? [Re: Sweet5ltr]
moparx Offline
Dreaming of implants
Loc: north of coder
nice chart ! up thank you !
beer
#2414741 - 12/07/17 12:31 PM Re: Will this rim and tire Combo fit my Charger? [Re: Frankenduster]
Loc: eastern,Ky
Originally Posted By Frankenduster
More
Thanks, that combo looks great!
#2454450 - 02/20/18 07:50 AM Re: Will this rim and tire Combo fit my Charger? [Re: Sweet5ltr]
Loc: eastern,Ky
I’ve seen a few people use this chart with success. I thought about using a 18x8 for the front which had a 4.50 backspacing and +1 offset and according to the chart that would only have me +1 off and the back rim which is 5.25 backspacing with +8 offset and according to the chart I would be off +2 with the offset. So if I am reading the chart correct my I shouldn’t have any problems with putting the 295 on the back??? Thanks!
Edited by 70RT Charger (02/20/18 08:18 AM)
25,348 Registered Members
190,243 Topics
What now for this b1 exhaust port
by kevinlc
35 minutes 48 seconds ago
engine id from bottom of engine up on a lift
by orange elephants
39 minutes 34 seconds ago
Which Scirocco Style Radiator??
by Blucuda413
40 minutes 17 seconds ago
Near tragedy in Kentucky today.
by Challenger 1
Today at 07:36 PM
