#2412300 - 12/02/17 02:11 PM Chevy vette engines
NTOLERANCE Offline
Loc: Madison Wi
Just picked up a few GM parts.
80vette engine 80k miles. Running when pulled for an upgrade.
LT1 engine. Aluminum heads. Low miles super clean inside.
A pair of alum LT1 heads and two intakes.
Wiw?
This post has been edited from its original form
Reason: Way too friggen drunk.
I was Mopar when Mopar wasnt cool and life was just a bet on a race between the lights.
#2412449 - 12/02/17 07:30 PM Re: Chevy vette engines [Re: NTOLERANCE]
Centerline Offline
Loc: Texas Hill Country
Hope you have the documentation to prove its a Corvette motor. These days it seems all SBC engines that are for sale are "Corvette" engines.
Centerline
32 Ford 3 Window Coupe 331 Hemi
64 Dodge Polara factory BB 4 speed
#2412456 - 12/02/17 07:46 PM Re: Chevy vette engines [Re: NTOLERANCE]
EV2Bird Offline
On Vacation
Loc: Kansas Roads Between 0 and 140...
Is any documented brand motor from 1980 worth much?
1980+chevy= not much
#2412525 - 12/02/17 10:08 PM Re: Chevy vette engines [Re: NTOLERANCE]
EWJ Offline
Loc: Waiting for the night the ligh...
Not sure if you ar speaking LT-1 or LT1. 1970-1972 LT-1 did not come with aluminum heads. 1992-1997 LT1 did. The later engine does not have any significant value, especially with the great success the LS series engines have been. Anyone looking to do a motor swap to a "late model" Chevy motor just goes for an LS.
If what you aquired is an LT-1, then you need to determine if it is a 1970-71 or a 1972. The 1972 was hyd lifters. Regardless of year, they would have a decent value with the Vette resto crowd. If it is an LT-1, then maybe the heads are over the counter GM performance pieces. Maybe a good pair would be worth $500-750 if truly good used.
The LT-1 came with an aluminum intake. Good examples can pull $350.
The 1980 Corvette motor is worth nothing more than what a regular good running SBC would garner in your local market. They had little improvement over a 350 in a Caprice.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1969 Satellite Conv: H code 383/4 speed, N85
1970 Super Bee: 383/4 speed F8/F8
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
#2412548 - 12/02/17 11:37 PM Re: Chevy vette engines [Re: NTOLERANCE]
NTOLERANCE Offline
Loc: Madison Wi
Would a vette engine have four bolt mains?
And this would the the later LT1 engines. Not the 1970's version
#2412555 - 12/03/17 12:27 AM Re: Chevy vette engines [Re: NTOLERANCE]
NTOLERANCE Offline
Loc: Madison Wi
I would think that the aluminum heads would have a $200 value or so ???
#2412560 - 12/03/17 12:41 AM Re: Chevy vette engines [Re: NTOLERANCE]
EWJ Offline
The motor with alum heads is a Vortec series motor- not a Gen II LT1. They were never used in Corvettes. Vortec 5.7 engines are a decent platform and the heads are a decent piece for a build on the cheap. I'd say they would be worth $200, but who knows.
Does look very clean for certain.
Ed
#2412561 - 12/03/17 12:43 AM Re: Chevy vette engines [Re: NTOLERANCE]
EWJ Offline
Check the suffix codes on the other motor. ZBC or ZBD is L-82. ZAK or ZAM is L-48.
Ed
#2412668 - 12/03/17 11:18 AM Re: Chevy vette engines [Re: NTOLERANCE]
karmakritters Offline
The block is a vortech block but the heads are not vortech style heads. Check the casting on the heads they may hold some value. Vortech heads do only have four intake bolts on each head.
#2412769 - 12/03/17 04:27 PM Re: Chevy vette engines [Re: EWJ]
NTOLERANCE Offline
Loc: Madison Wi
ZAM L-48. Pretty plane Jane engine I guess.
#2412921 - 12/03/17 11:26 PM Re: Chevy vette engines [Re: NTOLERANCE]
BS27R1B Offline
Loc: Cobourg, Ontario
Chev used the four bolt main 350 block in tens of thousands of cars and trucks, late 60s to late 70s., maybe longer in the trucks.
The key to the early LT-1 is the pistons, cam, intake, carb and 186 heads.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
#2413105 - 12/04/17 12:39 PM Re: Chevy vette engines [Re: NTOLERANCE]
floridian Offline
Loc: Lakeland FL
I had 4 friends with 70 LT1 Z28's back in the day.. 2 others with 71's and a third with a 72... I had a 73..
The 70's were scary fast.....
#2413554 - 12/05/17 10:32 AM Re: Chevy vette engines [Re: floridian]
moparx Offline
Loc: north of coder
seems there are more corvette engines than there were corvettes made. biggrin
beer
#2413619 - 12/05/17 12:46 PM Re: Chevy vette engines [Re: moparx]
floridian Offline
Loc: Lakeland FL
beer
Better than that, back in the mid 70's I was looking at buying a C2 vette ( 63-67) ALL of the "big block" cars ( the hoods are different) I looked at had blown up and had small blocks in them...
Kinda chuckle when I see all of the "Original " BB engine vettes being sold...
Edited by floridian (12/05/17 12:46 PM)
#2414678 - 12/07/17 10:44 AM Re: Chevy vette engines [Re: floridian]
moparx Offline
Loc: north of coder
beer
i have seen the big block vette situation first hand. new block, re-stamped with the "correct" numbers [using a correct date coded block of course], and bingo ! A-OK. and when sold, new owner was told about the block swap, and the first question asked was, "i hope you re-stamped the block ?" this was a 65 convertible 4spd by the way.
beer
#2415085 - 12/08/17 12:12 AM Re: Chevy vette engines [Re: moparx]
rhad Offline
Loc: garnett kansas
i know a guy with a vette that needed a different block with the correct date code,he found one that was bored way oversize,so he bought it and had all 8 sleeves done to make it standard again,had it restamped with the correct font and WALLA a original block in his vette!!
my ladder of success is missing some rungs
25,068 Registered Members
185,584 Topics
spark plugs ?
by sixbbl 69
01/18/18 12:06 AM
A100 power steering
by 2002bluert
01/17/18 10:00 PM
W23 Recall Wheel Price
by 2002bluert
01/17/18 09:58 PM
Low Friction Upper Control Arm Ball Joints, Opinions?
by moparAL
01/17/18 09:49 PM
