#2414278 - 12/06/17 01:49 PM Front Disc Brake Swap 68 B Body
fury4speed Offline
What is a good front brake disc conversion , I have a B body with factory non power drums , looking for the best deal that will fit with no problems , thanks
#2414389 - 12/06/17 06:23 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
AndyF Offline
Loc: Oregon
Need a little more information. Do you have a anti-sway bar? Do you have 15 inch wheels? Do you want stock parts so you can buy replacement parts at a NAPA or do you want something that looks aftermarket?
DoctorDiff probably has everything you need so start there. If that doesn't turn your crank there are a couple of other choices such as Baer.
#2414392 - 12/06/17 06:27 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
upnover Offline
Loc: tulsa ok
doctor diff was the cheapest that i saw, most of the others offered use chevy calipers..............
#2414414 - 12/06/17 06:59 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
Loc: Lincoln Nebraska
I'm thinking the '73-76 A body slider discs would fit. If so & you get a used setup get some rebuilt calipers at your parts house for a '76 A body as they have 2.75" calipers as opposed to 2.60" calipers for more front bias (almost always a good thing). they are identical in price & external dimentions/fitment.
#2414424 - 12/06/17 07:11 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
blewbyu Offline
Loc: Florida
I put a set of 73- up A Body on my 69 B Body
#2414477 - 12/06/17 08:43 PM Re: Front Disc Brake Swap 68 B Body [Re: RapidRobert]
AndyF Offline
Loc: Oregon
Yeah they'll fit if you can find them. A body stuff is hard to find in wrecking yards anymore. DoctorDiff has reproduction stuff all new in the box.
#2414496 - 12/06/17 09:26 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
hyefatman Offline
Loc: fresno
mounted calipers to the rear and shaved bolt ...everything clears waiting on hoses
#2414639 - 12/07/17 09:33 AM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
fury4speed Offline
This is a 1968 Belvedere wagon , it has 15 wheels , no sway bar , stock parts are better , thanks
#2414672 - 12/07/17 10:37 AM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
AndyF Offline
Loc: Oregon
If it was me I'd put the '73+ knuckles on there with 11.75 factory rotors and front hung calipers. Classic Mopar Action disc swap. Find the parts used or buy reproductions from DoctorDiff.
#2414719 - 12/07/17 12:08 PM Re: Front Disc Brake Swap 68 B Body [Re: AndyF]
krautrock Offline
Loc: central texas
this is exactly what i did on my 67 coronet.
already had the FMJ spindles, you can order new spindles from Doctor Diff.
got the 11.75" rotors and adapters from Doctor Diff.
Also used his stainless brake hoses for front mounting the calipers because i think the brake hose routing is cleaner this way.
calipers were just remans for a 76 dart which should be a 2.75" piston.
#2414723 - 12/07/17 12:14 PM Re: Front Disc Brake Swap 68 B Body [Re: AndyF]
rapom Offline
Loc: Northern OH
I bought a whole kit from dr. diff for my 68 charger and was very impressed at how well it bolted together and how it worked. He helped me identify my existing booster because he said a dual diaphram booster would work better in my application.
Turned out I had the single. How many guys would have told you that. And I probably wouldn't have been happy with the pedal pressure to stop if I would have stayed with the single.
Bottom line it stops like a modern car now.
#2414743 - 12/07/17 12:42 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
Sweet5ltr Offline
Loc: Florida
Edited by Sweet5ltr (12/07/17 12:48 PM)
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
#2414772 - 12/07/17 01:40 PM Re: Front Disc Brake Swap 68 B Body [Re: fury4speed]
fury4speed Offline
Thanks for all the good info
25,631 Registered Members
195,597 Topics
Driveshaft transmission yoke engagement question
by 440mopar
Yesterday at 11:13 PM
Rear seat difference- 2 door versus 4 door
by NHCharger
Yesterday at 09:46 PM
A look at Classic Industries 71-74 B-body A-pillar molding
by Fab64
Yesterday at 09:37 PM
727 questions
by frank
Yesterday at 08:28 PM
