Trans interchange Ramcharger to Dakota
#2414464
12/06/17 11:13 PM
12/06/17 11:13 PM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I am thinking of buying a 93 Dakota 4x4 with plow that has a trans with no reverse. I have a 93 Ramcharger 4x4 with a good trans and toasted body, are they the same trans and will they interchange, they are both 5.2 V8's?
JB Rhinehart, Realist
A-Body's RULE!
Re: Trans interchange Ramcharger to Dakota
[Re: Mr. Smurf]
#2414559
12/07/17 02:59 AM
12/07/17 02:59 AM
Posts: 954 garnett kansas
rhad
garnett kansas
the 93 tcase was a one year only deal, on Dakotas, something about the spline count on the input shaft i think?,as for the trans,it should go right in,i presume both are A518,or whatever they were called that year?
my ladder of success is missing some rungs
[Re: moparmarks]
#2414602
12/07/17 10:48 AM
12/07/17 10:48 AM
Rhinodart
Rhinotruck
Rhinotruck
The Dakota may have an A500 and the Ramcharger should have an A518. Bolt in differences?
A-Body's RULE!
[Re: Rhinodart]
#2414603
12/07/17 10:54 AM
12/07/17 10:54 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
The 5.2 Dakotas came standard with the 518. A 3.9 came with the 500.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Rhinodart]
#2415299
12/08/17 04:47 PM
12/08/17 04:47 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
They can bolt in if you have all the right stuff.
If the dak is a 500 and the ramcharger a 518 then the dipstick and tube are different and need to be kept with the trans.
There is an extra bolt hole on the dakota case where the front diff bracket bolts to the case, the dakota uses 2 bolts on that bracket, if you run the ram case you will have one of those two bolts missing, I don't think it is a big deal, I have done a few swaps with no issues so far.
The 500 is around 1/2 inch shorter, I have never had an issue just swapping them and letting the slip yolks make up the difference.
I have never run accross a spline count issue but I would never say never.
Also never having lived in the rust belt (thank the lord) I have never seen an issue rusting out dakota frames.
