Innova 3568 advance timing light #2414416
12/06/17 10:01 PM
12/06/17 10:01 PM
SD
Z
zrxkawboy Offline OP
Z
SD
Does anyone have one of these, and do you like it? I have a standard timing light, but always wanted an advance light. I was asked to pick out a Christmas gift in the $75 range, and Amazon has these for $70.
https://www.innova.com/en-US/Product/Detail/3568
It's Swifty! Swifty, you toad sucker!
Re: Innova 3568 advance timing light [Re: zrxkawboy] #2414522
12/07/17 01:07 AM
12/07/17 01:07 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It's pretty good. I can't tell you how much internal slew (delay) there may be but I think its reasonably fast.
I like being able to read the rpm and advance. Dial back has been handy on the dampers without a timing tape.
Light itself is reasonably bright. Similar to both my craftsman and my MSD.
Re: Innova 3568 advance timing light [Re: zrxkawboy] #2414539
12/07/17 01:46 AM
12/07/17 01:46 AM
SD
Z
Z
SD
Thanks for the feedback!
Re: Innova 3568 advance timing light [Re: Mattax] #2414569
12/07/17 03:33 AM
12/07/17 03:33 AM
Matt what is that internal delay?
Re: Innova 3568 advance timing light [Re: zrxkawboy] #2414638
12/07/17 12:32 PM
12/07/17 12:32 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There are not many companies making timing lights, anymore. The only down side to dial back timing lights like that is that they don't like multi strike ignitions. They can throw multiple flashes making it all but impossible to set timing on multi strikes. The tach is a nice feature.
I have 4 or 5 timing lights in the shop now. We use them more for diagnosing problems than we do to time. Not many people use them anymore, so they pop up ever so often on Craigslist.
This summer, I bought a nice Craftsman inductive light still in the case for $20.
Master, again and still
Re: Innova 3568 advance timing light [Re: zrxkawboy] #2414770
12/07/17 04:38 PM
12/07/17 04:38 PM
ILL
Greentween Offline
Greentween  Offline
ILL
I have an Innova light and happy with it so I would recommend to get it. Video of me using it on my ZZR1200.
https://www.youtube.com/watch?v=WG6V9Hp-O6A
Re: Innova 3568 advance timing light [Re: DaveRS23] #2414982
12/07/17 11:21 PM
12/07/17 11:21 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The electronics take time to process. The more decisions it makes internally, the longer it takes. Normally no one notices. But on an engine spinning 5 or 6000 rpm or faster, that time can equal a degree, or two, or three.
"For some perspective do the math:
6000RPM / 60 = 100 revolutions per second X 360 degrees = 36,000 degrees per second.
Each degree is 1/36,000th of a second or .00002778 sec."
from Spark Lead (you may have to join speedtalk to see this thread)
More in these speedtalk threads, which don't require joining:
HEI - Retarding, Slew
Timing Light inductive delay
Originally Posted By DaveRS23
The only down side to dial back timing lights like that is that they don't like multi strike ignitions. They can throw multiple flashes making it all but impossible to set timing on multi strikes. ...
I bought MSD's light because I was concerned about that problem. The Innova seems to be OK with my MSD 6T. I also have a Craftsman inductive and should compare. But current engine doesn't have a timing tape on it, so thats a ways off.
But when I was looking for the speedtalk posts on slew, there was also this one about problems with an MSD.
http://speedtalk.com/forum/viewtopic.php?f=1&t=33249
Re: Innova 3568 advance timing light [Re: Mattax] #2414986
12/07/17 11:26 PM
12/07/17 11:26 PM
Thank you. I got (2) dial backs, both sears craftsman, one an "advance timing light" & another a "professional timing anaylzer" & not sure what the difference is between the two & no multispark ignitions.
