Edelbrock idles too fast
#2414368
12/06/17 08:22 PM
12/06/17 08:22 PM
Posts: 549 WV
JohnH
WV
440 engine,, EB carb... Car goes 35 mph at idle,, I did everything I know to do to slow it down... Even tighten return springs,, And it's not the throttle cable set back too far,, I can pull the throttle back by hand and it will go to 750 rpm...Not the choke,, not the idle screw, not the choke,, not the cold idle cam,,, but when I shove the accelerator down, same problem,, And it seems as if the 4 barrel never kicks in.. A friend of mine has a 65 chevy, 350,,, has the same problem.. any ideas? Thanks...
Re: Edelbrock idles too fast
[Re: JohnH]
#2414380
12/06/17 08:56 PM
12/06/17 08:56 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Check the vacuum port as suggested above. If you have the mixtures/jetting off it is possible to adjust the throttle blades high enough to uncover too much of the transition slot in the primary venturis. That will lead to idle issues.
[Re: JohnH]
#2414410
12/06/17 09:56 PM
12/06/17 09:56 PM
RapidRobert
I can pull the throttle back by hand and it will go to 750 rpm. but when I shove the accelerator down, same problem,, And it seems as if the 4 barrel never kicks in. (1) throttle blades sticking (2) may need to lighten the counterweights (Then you can add weight back on to fine tune as needed)
[Re: JohnH]
#2414582
12/07/17 08:21 AM
12/07/17 08:21 AM
Posts: 9,815 MI, usa
dvw
MI, usa
Most likely the fast idle cam is sticking. This will lock out the secondary's as well. I have seen loose throttle blade screws cause this condition also. Look here, Page 8. If you have no choke, this linkage must be wired open. https://www.google.com/search?q=edelbroc...sourceid=chromeDoug
[Re: JohnH]
#2433562
01/12/18 07:29 PM
01/12/18 07:29 PM
feets
Senior Management
Senior Management
Irving, TX
Good to know it was an easy fix.
Thanks for filling us in.
[Re: feets]
#2433643
01/12/18 10:49 PM
01/12/18 10:49 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Thanks for filling us in. Agreed. And now I know I should check my "s" linkage on the Carter I rebuilt, to make sure it is properly installed.
I have mechanical Aptitude. I can screw up anything.
