Edelbrock idles too fast #2414368
12/06/17 08:22 PM
12/06/17 08:22 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
440 engine,, EB carb... Car goes 35 mph at idle,, I did everything I know to do to slow it down... Even tighten return springs,, And it's not the throttle cable set back too far,, I can pull the throttle back by hand and it will go to 750 rpm...Not the choke,, not the idle screw, not the choke,, not the cold idle cam,,, but when I shove the accelerator down, same problem,, And it seems as if the 4 barrel never kicks in.. A friend of mine has a 65 chevy, 350,,, has the same problem.. any ideas? Thanks...
Re: Edelbrock idles too fast [Re: JohnH] #2414378
12/06/17 08:46 PM
12/06/17 08:46 PM
cmansell Offline
cmansell  Offline
If you have it hooked to full vaccumn that can cause high idle, move to ported and see if that helps.
Re: Edelbrock idles too fast [Re: JohnH] #2414380
12/06/17 08:56 PM
12/06/17 08:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Check the vacuum port as suggested above.
If you have the mixtures/jetting off it is possible to adjust the throttle blades high enough to uncover too much of the transition slot in the primary venturis. That will lead to idle issues.
- Stu Harmon
Re: Edelbrock idles too fast [Re: cmansell] #2414393
12/06/17 09:32 PM
12/06/17 09:32 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I have vacuum connected to power brake booster,, is that what you mean full vac?
Re: Edelbrock idles too fast [Re: cmansell] #2414394
12/06/17 09:33 PM
12/06/17 09:33 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Full vac off intake that is,,,
Re: Edelbrock idles too fast [Re: JohnH] #2414410
12/06/17 09:56 PM
12/06/17 09:56 PM
I can pull the throttle back by hand and it will go to 750 rpm. but when I shove the accelerator down, same problem,, And it seems as if the 4 barrel never kicks in.
(1) throttle blades sticking (2) may need to lighten the counterweights (Then you can add weight back on to fine tune as needed)
Re: Edelbrock idles too fast [Re: JohnH] #2414432
12/06/17 10:18 PM
12/06/17 10:18 PM
Morristown Tn.
71birdJ68 Online content
71birdJ68  Online Content
Morristown Tn.
They are talking about the two vacuum ports on the front of the carbs, where the distributor hose goes.
Re: Edelbrock idles too fast [Re: JohnH] #2414478
12/06/17 11:44 PM
12/06/17 11:44 PM
Medford OR
FrankenScamp Offline
Medford OR
Re: Edelbrock idles too fast [Re: JohnH] #2414582
12/07/17 08:21 AM
12/07/17 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Most likely the fast idle cam is sticking. This will lock out the secondary's as well. I have seen loose throttle blade screws cause this condition also. Look here, Page 8. If you have no choke, this linkage must be wired open.
https://www.google.com/search?q=edelbroc...sourceid=chrome
Doug
Re: Edelbrock idles too fast [Re: JohnH] #2415269
12/08/17 03:38 PM
12/08/17 03:38 PM
central il.
second 70 Offline
second 70  Offline
central il.
John I had one where the accelerator pump linkage would hang up. I fixed it by reversing the S looking clamp that inserts in the accelerator pump and arm. Easy to check just take off the pump squirt and see if it goes away.
Took forever to find it. You could run the throttle by hand and everything was fine but the minute you drove it it would stick. Rev it and it would go back to idle. push throttle and stuck again.
This was on a two four barrel hemi with chokes removed and only one carb was sticking.
Mike
Re: Edelbrock idles too fast [Re: JohnH] #2415498
12/08/17 11:27 PM
12/08/17 11:27 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Are you sure your engine (or your accessories, vacuum advance, PB booster, vacuum hoses, intake gasket, etc.) does not have a vacuum leak? That's the main reason you cant reduce the idle speed.
Re: Edelbrock idles too fast [Re: JohnH] #2433068
01/11/18 10:02 PM
01/11/18 10:02 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Since it warmed up enough in the garage to figure out my engine idling to fast, I found the problem... It was my kick down lever where it attached to the carb binding somewhat.. I made some adjustments... All is well... Thanks for everyone's help...
Re: Edelbrock idles too fast [Re: JohnH] #2433562
01/12/18 07:29 PM
01/12/18 07:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Good to know it was an easy fix.
Thanks for filling us in.
- Stu Harmon
Re: Edelbrock idles too fast [Re: feets] #2433643
01/12/18 10:49 PM
01/12/18 10:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Agreed.
And now I know I should check my "s" linkage on the Carter I rebuilt, to make sure it is properly installed. up
I have mechanical Aptitude.
I can screw up anything.
