#2414118 - 12/06/17 09:12 AM Removing K-Frame/Engine from Bottom - 69 Dart
Pntastar69 Offline
Loc: Gilbertsville, PA 19525
In the process of removing the k-frame/engine/trans from the bottom. Can I use the ends of the bumper brackets as the lifting point to attach the hoist? Will they support the weight?
Mark
#2414136 - 12/06/17 09:37 AM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
dodgy Offline
Loc: Australia
have done what you describe however I used two bits of angle iron instead of the bumper brackets with a bar joining the two together with lift point centred, not a lot of weight after motor trans and front end is unbolted.
#2414138 - 12/06/17 09:38 AM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
Neil Offline
Loc: Eagle, Idaho
I think you would want to put something in-between them so they don't pinch together.
#2414145 - 12/06/17 09:55 AM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
Pntastar69 Offline
Good point Neil. My plan is to bolt a 2 x 2 x 1/4" square tube to the front of the brackets.
Mark
#2414295 - 12/06/17 02:22 PM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
Neil Offline
Loc: Eagle, Idaho
That should work. Bumper brackets should be more that strong enough to lift the front end up.
#2414495 - 12/06/17 09:24 PM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
davesmopars Offline
Loc: cheshire, ct
Get the rear tire off the ground also 6 to 10 inches you will not have to lift the front as high
#2414583 - 12/07/17 05:45 AM Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69]
Pntastar69 Offline
Thanks guyz.
Mark
25,246 Registered Members
188,828 Topics
Are "Mopar Performance" valve cover stickers reproduced ?
by varunner
04/20/18 08:13 AM
TracFone Experience
by Confused Mopar
04/20/18 07:36 AM
Did All 70 B Body 4 Speeds Have 2 Shifter Mounting Location?
by 70X
04/20/18 04:09 AM
Accessory Belt Issue....... Help!
by StealthWedge67
04/20/18 12:13 AM
