Removing K-Frame/Engine from Bottom - 69 Dart #2414118
12/06/17 12:12 PM
12/06/17 12:12 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
In the process of removing the k-frame/engine/trans from the bottom. Can I use the ends of the bumper brackets as the lifting point to attach the hoist? Will they support the weight?
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414136
12/06/17 12:37 PM
12/06/17 12:37 PM
Australia
dodgy Offline
dodgy  Offline
Australia
have done what you describe however I used two bits of angle iron instead of the bumper brackets with a bar joining the two together with lift point centred, not a lot of weight after motor trans and front end is unbolted.
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414138
12/06/17 12:38 PM
12/06/17 12:38 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think you would want to put something in-between them so they don't pinch together.
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414145
12/06/17 12:55 PM
12/06/17 12:55 PM
P
P
Good point Neil. My plan is to bolt a 2 x 2 x 1/4" square tube to the front of the brackets.
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414295
12/06/17 05:22 PM
12/06/17 05:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
That should work. Bumper brackets should be more that strong enough to lift the front end up.
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414495
12/07/17 12:24 AM
12/07/17 12:24 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Get the rear tire off the ground also 6 to 10 inches you will not have to lift the front as high
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Removing K-Frame/Engine from Bottom - 69 Dart [Re: Pntastar69] #2414583
12/07/17 08:45 AM
12/07/17 08:45 AM
P
P
Thanks guyz.
