Re: Who knows Winches? Can it be repaired ?
[Re: RUMBLON]
#2413808
12/05/17 08:40 PM
12/05/17 08:40 PM
dogdays
How about giving them a shout? https://milemarker.com/replacement-parts/Easier than cobbling something together. There is probably an electric motor rebuilding shop in Boise that could help. The more you disassemble and clean, the lower the bill will be. R.
[Re: RUMBLON]
#2413991
12/06/17 01:04 AM
12/06/17 01:04 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I believe they have brushes. Could be just a brush issue - personally I would whack it with a hammer to see what happens. If works its a brush issue. If that don't work I would tear it apart and look at the brush assembly.
[Re: RUMBLON]
#2414181
12/06/17 01:59 PM
12/06/17 01:59 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Mile Marker is known for their hydraulic winches. Is yours hydraulic with electric controls or electric?
[Re: RUMBLON]
#2415549
12/09/17 12:59 AM
12/09/17 12:59 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Ever had a Chrysler starter apart, ever rebuild one? Stator, armature, brushes, bushings or bearings at either end of the stator, maybe a relay wih contacts needing cleaning. Most DC motors are similar in construction. You got nothing to lose. Sand the contacts on the stator, clean the spaces between them, brushes can made or bought. Clean all the dust out, oil the bushings/bearings, etc. If you can rebuild a carb you can do a dc motor. Take pictures as it comes apart and have at it. Or an alternator/starter rebuild shop might tackle it.
[Re: RUMBLON]
#2416056
12/10/17 03:31 AM
12/10/17 03:31 AM
Posts: 43,112 Bend,OR USA
Cab_Burge
Is it reversible or in only? How do you control it, wireless or handheld controller ? How old is this unit, when was it made ?
