Rearend gear selection help needed.
#2413734
12/05/17 07:00 PM
12/05/17 07:00 PM
Posts: 831 Missouri
galen
Missouri
This is mainly a cruise night type car that will be making a few 100 plus mile trips for shows, etc. 68 Plymouth Satellite. Engine is a 588, Koleno block, 572-13 heads. Peak torque 817 at 6200. Redline 7000rpm. Tires are M&H 325/45/17 drag radials 28" diam. I am a paraplegic and drive with hand throttle and brake. In turn I opted for a fully programmable TCI 6X with upgrades. Gear ratios are 2.97,2.23,1.57,1.18,1.00,0.75. 3600 stall. I am leaning toward a 3.73 in a Strange S60. I want acceleration more than top end. It is a heavy all steel car, AC etc. I value your opinions. Thanks, Galen
Re: Rearend gear selection help needed.
[Re: galen]
#2413739
12/05/17 07:09 PM
12/05/17 07:09 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Even a 3.54 would be plenty,Thats a healthy engine!!
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2413751
12/05/17 07:21 PM
12/05/17 07:21 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yeah with that 2.97 first gear a 3.54 will be plenty. I had a 3.27 low gear in my Richmond and 3.54 gears in the rear and it came out of the hole quite nicely Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2413752
12/05/17 07:22 PM
12/05/17 07:22 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
With that first gear ratio and a 28" tall tire, I'd go w/ 3.54s.
[Re: galen]
#2413840
12/05/17 09:44 PM
12/05/17 09:44 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3.73 or even a 3.54 with those gear ratios? It's going to be a tire baking machine. Honestly, if you could eliminate using the 2.97 and just use 2.23 as low gear, it would work much nicer I think. Then maybe the 3.73 is manageable. 3.73x2.23=8.32 And with the overdrive, it will be OK on the highway.
[Re: galen]
#2414162
12/06/17 01:29 PM
12/06/17 01:29 PM
an8sec70cuda
dvw...I agree that even a 3.54 w/ his 1st gear is too much SLR for his motor, but (as you know) the 3.54 is the lowest numerically commonly available gearset for the Dana. If he could find a taller gear, not sure what Strange has for them, that'd definitely be better. The car is set up more like a street cruiser even though it has a serious motor, so the 3.54 will likely be fine for him. It'll be like driving on ice from a dig though w/ that SLR and 17" drag radials on the street.
[Re: galen]
#2414612
12/07/17 11:31 AM
12/07/17 11:31 AM
an8sec70cuda
Pros and cons both ways on the tires. The drag radials drive a lot better, but won't hook nearly as good on the street as a bias ply tire. If you're concerned w/ traction, go w/ a bias ply tire but use a sticky one...like the Hoosier Quicktime Pro or M/T ET Street. Don't waste your time w/ a M/T sportsman or the normal quicktime tire. They are bias ply, but will handle like one AND not hook worth a damn.
If traction is your main concern, stick w/ a 15" rim.
[Re: galen]
#2414641
12/07/17 12:39 PM
12/07/17 12:39 PM
Posts: 4,206 New York
polyspheric
New York
What does your converter manufacturer say is your minimum cruise RPM for acceptable converter slip?
Boffin Emeritus
