Re: Starting to work on the Duster
[Re: AndyF]
#2509640
06/17/18 03:36 PM
06/17/18 03:36 PM
Posts: 30,947 Oregon
AndyF
[Re: AndyF]
#2509869
06/18/18 09:55 AM
06/18/18 09:55 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Nice progress. Loaded with new ideas for the rest of us!
2 kids and a dog
[Re: varunner]
#2575674
11/08/18 01:21 AM
11/08/18 01:21 AM
Posts: 4,457 Washington
madscientist
Washington
Very nice work Andy. Question, have you covered in another thread what your thinking is concerning the pvc valve ? I see it's adjustable and I'm wondering if it adds horsepower which you'd see on the time slip. thanks Got some patch panels welded in and finished running the plumbing for fuel and trans cooler. Now I'm working on the wiring as I get time. I have that Wagner PCV valve that I'm going to do some testing with. I'm not using it like a conventional PCV and Wagner knows it. I've done a bit of testing with it, but not enough to say what I'm doing will work.
[Re: AndyF]
#2582776
11/25/18 01:17 PM
11/25/18 01:17 PM
Posts: 1,030 ohio
67mprfan
ohio
Which motor are you going to install since you sold the 470
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: AndyF]
#2583155
11/26/18 11:17 AM
11/26/18 11:17 AM
Posts: 34,831 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I also enjoy the car craft articles you do, good reading
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: AndyF]
#2583186
11/26/18 01:13 PM
11/26/18 01:13 PM
TonyS451
Chicago, IL
Nice work. One of the perks of using a motor plate, you get to mock up your cooling system.
2 kids and a dog
[Re: TonyS451]
#2583242
11/26/18 03:15 PM
11/26/18 03:15 PM
AndyF
Nice work. One of the perks of using a motor plate, you get to mock up your cooling system. Yeah I was thinking I needed to drop the engine into the car to check the clearances then I realized that I could just bolt the motor plate in and use that. Saved me a lot of time.
[Re: AndyF]
#2583323
11/26/18 06:30 PM
11/26/18 06:30 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Here is a shot of some of the extra bracing added to the front of the car. We also installed the torque boxes but those are a little harder to get a shot of. I like that Are you thinking of marketing them? If so I'll take a pair
[Re: AndyF]
#2583370
11/26/18 08:00 PM
11/26/18 08:00 PM
AndyF
[Re: TonyS451]
#2583427
11/26/18 10:31 PM
11/26/18 10:31 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Nice work. One of the perks of using a motor plate, you get to mock up your cooling system. Sometimes the simplest ideas are brilliant! I was thinking I would mock up cooling on my g3 swap while I was test fitting a bare block. Since I'm using a motor plate, AndyF has shown me the light! At the same time, I'm feeling like...."Duh, Doug".
