Re: a body disc brake conversion .... caliper hitting swaybar
[Re: hemi71x]
#2413374
12/05/17 01:28 AM
12/05/17 01:28 AM
Posts: 213 fresno
hyefatman
fresno
[Re: hyefatman]
#2413445
12/05/17 03:17 AM
12/05/17 03:17 AM
Posts: 30,947 Oregon
AndyF
just need to know part number for brake hose when mounting calipers to rear of rotor It is more complicated than that. What you really want are calipers that are designed to be rear hung. They'll have the bleeder mounted at the top and the hose will come out on the bottom. When I used to do these brake swaps I never found an off the shelf hose that worked so I just braided hoses with the right ends. DoctorDiff might have a hose these days.
[Re: hyefatman]
#2413489
12/05/17 10:55 AM
12/05/17 10:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
RR has it right, but there is a bracket on the hose you need to pull off.
[Re: hyefatman]
#2413513
12/05/17 12:06 PM
12/05/17 12:06 PM
Posts: 213 fresno
hyefatman
fresno
Its is kinda funny that in most of all articles that I researched everyone says use parts from 1973-1976 a body for my 1969 a body disc brake conversion. That includes upper control arms and spindles - they only mention the sway bar issue in passing and say almost nothing about the lower control arm bolt hitting the sway bar bracket. After buying the parts and installing the 1973-1976 calipers on the front do I see this is not going to work. The moparts web site it says http://www.moparts.org/Tech/tech/pages/abody.html12. Sway Bars, this will not interfere with either the factory or aftermarket SWAY BARS, just weld on the tabs, for the Donor Car, or the brackets, that came with the aftermarket kit. (Yes, they do interfere because of the factory weld location on the lower control arm) 13. It is NOT adviseable to switch the Caliper from front to rear, the Chrysler engineers, found it best to place the caliper in the rear of the the spindel, to aid in heat transfer, and this also helps keep the road grime from entering the piston. (Why not, many have with no problems, if not changing from from to rear how will it clear without changing out the k frame and sway bar)
[Re: hyefatman]
#2413550
12/05/17 01:24 PM
12/05/17 01:24 PM
Supercuda
About to go away
About to go away
up yours
Yeah, that article has a lot of issues, including being wrong about a number of things. It should either be revamped and corrected or removed.
[Re: hyefatman]
#2413553
12/05/17 01:30 PM
12/05/17 01:30 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
The pic below is an "A" body disk conversion on a '64 "B" body. These are all mid 70's "A" body parts with the exception of the upper and lower control arms which are not required to be changed for the 62-65 "B" body conversion. The spindles and caliper adapters are from a '75 Dart and the calipers are from a '76 Dart. These are slider calipers. The rotors are from a '77 Dodge Monaco and are 11.75" diameter. There are no, nada, zero issues moving the calipers to the rear. At least this is true for the "B" body conversion and I suspect it will also apply to the "A" body conversion as well. All that's needed is to swap the spindles side to side. Swapping the spindles and moving the calipers to the rear is a VERY common mod when doing this conversion on 62-65 "B" body cars if they are equipped with a front sway bar. I do know that Dr.Diff has the proper hoses for the "B" body conversion and he probably has the correct hoses for the "A" body conversion as well.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: hyefatman]
#2413833
12/05/17 09:21 PM
12/05/17 09:21 PM
RapidRobert
moparts.com is the premier site for all Mopar information. Yes we're the best.
[Re: hyefatman]
#2413874
12/05/17 10:43 PM
12/05/17 10:43 PM
AndyF
moparts.com is the premier site for all Mopar information. I have been using this site for a ton of years. If the linked information is incorrect it should be removed or upgraded.
A lot of misinformation is posted on Moparts. I see wrong info posted almost every time I visit. People who visit the board on a regular basis usually figure out how to separate the wheat from the chaff but it is more of a challenge for the beginners. The biggest problem I see is that somebody does something once and they think that is the way to do it. Any engineer will tell you that a data sample of one isn't very robust. There are lots of things you can do on a car that work okay for a short period of time but would be complete disaster if the factory installed it on a million cars.
