Re: Main bearing spacers [Re: JesseR] #2413271
12/04/17 09:55 PM
12/04/17 09:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I wouldn't worry about if it would work. But why bother? By the time you get them made/machined, you could just buy the right crank and be done with it.
Re: Main bearing spacers [Re: dizuster] #2413276
12/04/17 10:03 PM
12/04/17 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I remember right MP use to sell them about
25 years ago.. I knew 1 guy the used them.. it
worked out fine for his street engine.. this
was on a SB.. but I havent heard of them in
a LONG time
wave
Re: Main bearing spacers [Re: MR_P_BODY] #2413303
12/04/17 10:55 PM
12/04/17 10:55 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
I appreciate all the responses about this. Fact is, I wanted to know if it’s been done, simple question. Will I do it, probably not at this point, just wanted some input on the subject.
82' dodge pickup with a 499 low deck
Re: Main bearing spacers [Re: JesseR] #2413315
12/04/17 11:25 PM
12/04/17 11:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Back in the day, the original bearing was the spacer.
Boffin Emeritus
Re: Main bearing spacers [Re: JesseR] #2413377
12/05/17 01:31 AM
12/05/17 01:31 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
If they were available I'd probably buy a set. I have access to a billet center weighted 400 mained 4.300 crank.
Re: Main bearing spacers [Re: polyspheric] #2413391
12/05/17 01:55 AM
12/05/17 01:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
Me thinks your talking about the beginning of times in American made cars whistling work
Re: Main bearing spacers [Re: JesseR] #2413400
12/05/17 02:09 AM
12/05/17 02:09 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Bill Jenkins 1973
Boffin Emeritus
Re: Main bearing spacers [Re: polyspheric] #2413403
12/05/17 02:11 AM
12/05/17 02:11 AM
I thought you where talking about the full floating rod bearings back a long time ago that I have heard of, never seen one myself either confused
Re: Main bearing spacers [Re: Cab_Burge] #2413446
12/05/17 03:18 AM
12/05/17 03:18 AM
Washington
madscientist Offline
Washington
Flat head ford stuff.
Re: Main bearing spacers [Re: Cab_Burge] #2413493
12/05/17 11:08 AM
12/05/17 11:08 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I only used them in the smallblock Chevy in my offshore boat ,,but that was years ago...Never had a problem..even at high RPM WOT for over an hour at a time..( in flat water) ..or jammin from full throttle no throttle and right back on to WOT ..in big water..
Re: Main bearing spacers [Re: JesseR] #2413581
12/05/17 02:44 PM
12/05/17 02:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Why stop at that size, go smaller, after all, smaller journals make more HP. It's not some voodoo thing.
Re: Main bearing spacers [Re: cudaman1969] #2413583
12/05/17 02:49 PM
12/05/17 02:49 PM
Size matters, especially when it comes to twisting and reversing metal repeatedly work
Re: Main bearing spacers [Re: Cab_Burge] #2413645
12/05/17 04:41 PM
12/05/17 04:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You mean like Johnsons rubber cranks Line was complaining about?
Speek get of cranks, go to the general forums and look at the Cummins engine dyno explosion. Had a good one in it, for awhile!
