Isky cam specs needed #2412381
12/02/17 08:43 PM
12/02/17 08:43 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I just pulled an Isky cam from my 340.The numbers on the end W77N 280HL hyd 3901.I googled it but didn't get much.Any idea what dur. or lift would be? Thanks for any replies.
Re: Isky cam specs needed [Re: 5carguy] #2412389
12/02/17 08:49 PM
12/02/17 08:49 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
For some reason this ended up in General and should have been in Questions and answers.Mods move it if you like.
Re: Isky cam specs needed [Re: 5carguy] #2412411
12/02/17 09:26 PM
12/02/17 09:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Isky cam specs needed [Re: Supercuda] #2413134
12/04/17 04:30 PM
12/04/17 04:30 PM
dogdays Offline
dogdays  Offline
Unless they've changed it along the way, this cam is a 40+ year old Chevy lobe design. That means two things:
1. There is more power to be had from a more modern, Mopar-specific lobe.
2. This cam should be easy on the valve train as it does not have the extremely fast acceleration rates of the modern cams suggested in the lines above.
I was looking at this camshaft in catalogs in the mid '70s. One step down, the 270HL, was considered to be a great street cam. The 256 and 262 Supercams are newer than this cam.
R.
