2008 Challenger......Gremlin Steve #2412271
12/02/17 03:58 PM
12/02/17 03:58 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
, I was bored lurking around MOPARTS , found this and was wondering What ever happened to this car
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/144470/2.html
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412308
12/02/17 05:32 PM
12/02/17 05:32 PM
houston texas
gremlinsteve Offline
houston texas
I've lost track of it
To be honest I'm sure it's making a lot more now as the tuning
Gurus have caught up to the builders
I've stepped away from full car builds a lot and stick more
With cam design now ect
My latest one is based off stool steel core running in the 275 @.050 range
And about 15:1 compression
It should make well over 900 on 426 Inches
https://youtu.be/x0Vbfn6fTfs
Steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 2008 Challenger......Gremlin Steve [Re: gremlinsteve] #2412346
12/02/17 07:26 PM
12/02/17 07:26 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
Steve
You make cams from steel from stools? Like bar stools?
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412359
12/02/17 08:03 PM
12/02/17 08:03 PM
houston texas
houston texas
Lol
Stupid phone
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412602
12/03/17 10:15 AM
12/03/17 10:15 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
glad he said bar stool, my crappy out look this week took me to a different part of the bar.
But seriously Steve , have you found any gains with more intake lift over , Exhaust example instead of say cam Lift I/E 502/528 Dur@50 208/212 , grind 528/502 Dur@50 208/212.
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412817
12/03/17 09:14 PM
12/03/17 09:14 PM
houston texas
houston texas
I have found gains in several ways
One it seems that they like a fast opening rate and then a slower closing rate lobe
They also appear to love reverse splits also
It just depends upon what your trying to achieve in the end and
What type of platform the motor will be in
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412823
12/03/17 09:28 PM
12/03/17 09:28 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Can a slower closing rate be equated to more duration in a sense?
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2412912
12/04/17 02:08 AM
12/04/17 02:08 AM
'murica
misfired Offline
misfired  Offline
'murica
Are you still using a stock cam core? If not do you bore the tunnel for roller bearings?
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2413428
12/05/17 02:49 AM
12/05/17 02:49 AM
houston texas
houston texas
I have yet to bore a cam tunnel on one
Or attempt at putting rollerized cam bearings into one
I have seen some of these late model cam cores gun drilled
Sometimes they are not
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2415172
12/08/17 12:29 PM
12/08/17 12:29 PM
'murica
misfired Offline
misfired  Offline
'murica
What diameter are the gen3 cams? I wonder if it would even be worth the work, obviously depends on how much diameter is to be gained.
Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt] #2415676
12/09/17 12:28 PM
12/09/17 12:28 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Pre VVT #1=2.29 VVT #1= 2.67
#2=2.28
#3=2.26
#4=2.25
#5=1.72
