Best single-bolt BB timing set #241239
03/02/09 08:36 PM
03/02/09 08:36 PM
WA 98043
thecarfarmer Offline OP
WA 98043
So, I've given up on trying to build the engine for my truck, and am 'calling in the cavalry'.
I took the boxes of parts down, and my builder nixed my $100 Comp Cams timing set - he doesn't like the (iron or sintered steel?) crank gear. Says they tend to be a little loose on crank snouts and fret under use w/ medium/heavy valve spring loads.
Guy has been building engines for about twenty years, and his employee for about 25. Think they may have had more experience watching failure patterns than I have.
The cam in question is a CAST single-bolt billet Engle roller I bought from Cab Burge about a year ago, 262 @ .050; .630" (with my HS 1.6:1 rockers). Springs are Herbert HERS637 doubles (200# seat; about 540# on the nose).
After spending a couple HOURS sanding burrs off the Comp cam gear (wish I'd saved that receipt!), just to have it 'nixed', I don't think I want to buy another Comp set.
Looking at the 440 Source (made in USA) set w/ the upgraded Rolon chain, and the Cloyes billet set shown at Summit .
Okay moparts faithful, what are your thoughts?
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Best single-bolt BB timing set [Re: thecarfarmer] #241240
03/02/09 08:37 PM
03/02/09 08:37 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Rollmaster with the IWIS chain.
Re: Best single-bolt BB timing set [Re: thecarfarmer] #241241
03/02/09 08:47 PM
03/02/09 08:47 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The last Summit brand timing set performed well, and had no signs of chain stretch after 60+ passes going mid to high 4's in the 8th mile. It has Made in the USA on the gears, which are billet. Had a torrington roller bearing for block wear. The chain was a DiD Brand chain which are very popular with dirt bike racing chains etc. But this was a 3 bolt setup.
IMHO
all of them stretch some, I install the cam one deg tighter than I intend. My new engine is a 572 Hemi that I have some money tied up in already. Solid flat tappet 3 bolt cam..
My timing chain choice...
a $45 Comp Cams version.. Non Billet gears, just good old Heat treated version, with a pre stretched over sized roller chain..
It will be the last thing on my mind when I drop the hammer on it.
Re: Best single-bolt BB timing set [Re: SSAAHemiFan] #241242
03/02/09 09:36 PM
03/02/09 09:36 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Re: Best single-bolt BB timing set [Re: thecarfarmer] #241243
03/02/09 11:04 PM
03/02/09 11:04 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
Ive had nothing but good luck with Pro Gear.
Re: Best single-bolt BB timing set [Re: 572B1] #241244
03/02/09 11:53 PM
03/02/09 11:53 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
same here.
Nautilus Racing-
Re: Best single-bolt BB timing set [Re: Chris2581] #241245
03/03/09 08:54 AM
03/03/09 08:54 AM
I double pin them . I add an extra pin and place it so the tension washer covers it. Not really too hard to do and I sleep a whole lot better in a race engine situation.
Don
