#2412271 - 12/02/17 12:58 PM 2008 Challenger......Gremlin Steve
ric3xrt Offline
Loc: Trumbauersville PA
, I was bored lurking around MOPARTS , found this and was wondering What ever happened to this car
http://board.moparts.org/ubbthreads/ubbthreads.php/topics/144470/2.html
#2412308 - 12/02/17 02:32 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
gremlinsteve Offline
Loc: houston texas
I've lost track of it
To be honest I'm sure it's making a lot more now as the tuning
Gurus have caught up to the builders
I've stepped away from full car builds a lot and stick more
With cam design now ect
My latest one is based off stool steel core running in the 275 @.050 range
And about 15:1 compression
It should make well over 900 on 426 Inches
https://youtu.be/x0Vbfn6fTfs
Steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
#2412346 - 12/02/17 04:26 PM Re: 2008 Challenger......Gremlin Steve [Re: gremlinsteve]
HotRodDave Offline
Loc: Kalispell Mt.
Steve
You make cams from steel from stools? Like bar stools?
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2412359 - 12/02/17 05:03 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
Loc: houston texas
Lol
Stupid phone
#2412602 - 12/03/17 07:15 AM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
ric3xrt Offline
glad he said bar stool, my crappy out look this week took me to a different part of the bar.
But seriously Steve , have you found any gains with more intake lift over , Exhaust example instead of say cam Lift I/E 502/528 Dur@50 208/212 , grind 528/502 Dur@50 208/212.
#2412817 - 12/03/17 06:14 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
Loc: houston texas
I have found gains in several ways
One it seems that they like a fast opening rate and then a slower closing rate lobe
They also appear to love reverse splits also
It just depends upon what your trying to achieve in the end and
What type of platform the motor will be in
#2412823 - 12/03/17 06:28 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
moparmitch Offline
Loc: Michigan
Can a slower closing rate be equated to more duration in a sense?
#2412912 - 12/03/17 11:08 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
misfired Offline
Loc: 'murica
Are you still using a stock cam core? If not do you bore the tunnel for roller bearings?
#2413428 - 12/04/17 11:49 PM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
Loc: houston texas
I have yet to bore a cam tunnel on one
Or attempt at putting rollerized cam bearings into one
I have seen some of these late model cam cores gun drilled
Sometimes they are not
#2415172 - 12/08/17 09:29 AM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
misfired Offline
Loc: 'murica
What diameter are the gen3 cams? I wonder if it would even be worth the work, obviously depends on how much diameter is to be gained.
#2415676 - 12/09/17 09:28 AM Re: 2008 Challenger......Gremlin Steve [Re: ric3xrt]
ric3xrt Offline
Pre VVT #1=2.29 VVT #1= 2.67
#2=2.28
#3=2.26
#4=2.25
#5=1.72
25,341 Registered Members
190,156 Topics
Most users ever online: 1,417 @ Yesterday at 08:39 PM
Yard equipment: Stihl vs. Honda?
by YYZ
19 minutes 57 seconds ago
Mopar Performance R3 block
by begood
28 minutes 24 seconds ago
air cleaners
by moparsquid
Today at 04:11 PM
Cuda and Challenger glass alike
by gregok
Today at 03:33 PM
