1990 ram bolt pattern swap #2411590
12/01/17 12:35 AM
12/01/17 12:35 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
I have a 1990 ram 150 two wheel drive with the 5.5" bolt pattern
I want to swap the rear end to an earlier 8 3/4 d100 axle with the 4.5" bolt circle
Is there a front rotor I can use to change the front bolt pattern to match
I already have the truck 8 3/4
Re: 1990 ram bolt pattern swap [Re: NTOLERANCE] #2411717
12/01/17 11:27 AM
12/01/17 11:27 AM
scratchnfotraction Offline
yes a 82-84 d series chassis = 84 d150 front rotor or 76 new Yorker rotors = same as truck rotor 82-84
you can also use a set of 72-74 W100-W150 8 3/4 axles with the 5 on 5.5
I used a set of those axle in a 74 C-body 8 3/4 housing on a truck project once already.
are you staying with stock width truck housing? 59" flange to flange?
same as a C-body housing 59" f2f
I have 1 stock 74 8 3/4 housing left with 74 c-body 5 on 4.5 axles.
I just moved perches and installed a 67 C-body (polara) in my 85 stepside. tucked 10" rims in nicely.
what size rim tire combo you going with?
is the rear lowered on the truck?
Re: 1990 ram bolt pattern swap [Re: NTOLERANCE] #2412157
12/02/17 11:04 AM
12/02/17 11:04 AM
Madison Wi
Madison Wi
Scratch. Thanks for the reply. I did some googling and confirmed the rotors that fit.
I didn't know the c body was the same width!
Truck isn't lowered. Planning to stay with the stock width.
I may lower it some but I'm not interested in slamming it.
15x10 wheels in the back. Something in the 30/31 inch tall tire that fills the wheel wells
I just got it running and the open 8.25 isn't going to cut it
I don't want c clip axles otherwise I'd go 9.25 and a Dana isn't I the budget
I figured 5x4.5 bolt pattern would open up used wheel choices too.
Re: 1990 ram bolt pattern swap [Re: NTOLERANCE] #2412488
12/02/17 11:42 PM
12/02/17 11:42 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Not sure about the interchange, but my 1974 d100 has 5 x 4.5 pattern on the disc brake rotors. Maybe check on rockauto.com to see if they interchange, or check to see if the inner and outer wheel bearings are the same.
Re: 1990 ram bolt pattern swap [Re: NTOLERANCE] #2412997
12/04/17 11:43 AM
12/04/17 11:43 AM
IIRc some of the early trucks used a larger bearing ID/spindle and will not fit the later spindles.
seems I tried a 78 rotor on my 85 spindle and the bearing did not fit.
not sure if you can change the race/bearing in those rotors or not. I returned them to the JY and got 76 new yoker rotors.
as far as stock width goes I was able to fit 10" rim with 4" back space 29x9.50x15 on my 9 1/4 had about 3/4" - 1" at fender lip on the stepside with no need to tub bed. lowered with flip flop on the axle.
4.5 backset will fit but I could not get a craiger v5 rim with the 4.5 BS only a 4"
IMO I think you could fit up to a 11.50 on a 10" rim 4.5 backset.
I have run a 10" 4.5 bs with a 275x60x15 as well, it's most popular around here.
