Windage Tray #2410863
11/29/17 07:03 PM
11/29/17 07:03 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
At the moment I am using the stock windage tray in my 440. The engine is apart at this time.
Is there a better option ( Type of tray) Out there. just trying to make some small improvements
Thanks Tom C.
Re: Windage Tray [Re: TOMRR] #2410865
11/29/17 07:06 PM
11/29/17 07:06 PM
an8sec70cuda Offline
The Milodon tray w/ the louvers in it will help oil drainback.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Windage Tray [Re: TOMRR] #2410943
11/29/17 08:50 PM
11/29/17 08:50 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Add some louvers to it. Wont cost nothing except time.
Re: Windage Tray [Re: TOMRR] #2411000
11/29/17 10:40 PM
11/29/17 10:40 PM
Enlarge or open the existing louvers on the top flat area primer wrench up
A crankshaft scraper is worth some more power above 5000 RPM also work
Re: Windage Tray [Re: TOMRR] #2411182
11/30/17 11:11 AM
11/30/17 11:11 AM
n.h.
ricks_RR Offline
ricks_RR  Offline
n.h.
hi TOMRR
hows the car
ricks_RR
Re: Windage Tray [Re: ricks_RR] #2411440
11/30/17 08:07 PM
11/30/17 08:07 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Originally Posted By ricks_RR
hi TOMRR
hows the car
ricks_RR
Hey Rick
The RR is great, The 440 is back in Ct. at Larry's Auto Mach.(The Rebuilder) after two summers and about 3500 mile developed a knock. So far the only thing they found was excessive wear on two Cylinder skirts.They are not sure at this time what caused that, talking to their CYL. Supplier . If all goes well should have it back by end of year. They will run and check after back together !!
Re: Windage Tray [Re: TOMRR] #2411699
12/01/17 10:35 AM
12/01/17 10:35 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
There was a post on here about Modifying the Stock Mopar windage tray. Does any one remember it , I can't seem to find it. I think it was a just a matter of drilling a few holes in the pan !!
Thanks Tom C,
Re: Windage Tray [Re: TOMRR] #2411771
12/01/17 02:12 PM
12/01/17 02:12 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content
moparmike1  Online Content
Re: Windage Tray [Re: moparmike1] #2411983
12/01/17 09:48 PM
12/01/17 09:48 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I have this one also but haven't installed it yet. It seems like it needs some extra holes on the bottom flat.
Re: Windage Tray [Re: TOMRR] #2414239
12/06/17 03:34 PM
12/06/17 03:34 PM
Locomotion Offline
Locomotion  Offline
I use their crank scrapers on my 360's, but here is what they have for big block Mopars.
Ishihara-Johnson crank scrapers
Re: Windage Tray [Re: TOMRR] #2414248
12/06/17 03:52 PM
12/06/17 03:52 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
I will be modifying my stock windage tray so that it drains better !!
