1965 A100 Auto Trans Cable Question #2411536
11/30/17 11:29 PM
11/30/17 11:29 PM
Las Vegas NV
MPCraig Offline OP
MPCraig  Offline OP
Las Vegas NV
Shifter cable broke and when I removed it I found the spring on the cable adaptor looks funky. Can someone tell me if this needs replaced? What is the part number?
[img]https://imgur.com/sSrW1QS[/img]
Re: 1965 A100 Auto Trans Cable Question [Re: MPCraig] #2411575
12/01/17 12:11 AM
12/01/17 12:11 AM
A727Tflite Online content
A727Tflite  Online Content
That's normal - the male end of your cable slips in to this adapter and a groove in the cable tip engages that "coil" spring.
Re: 1965 A100 Auto Trans Cable Question [Re: A727Tflite] #2411582
12/01/17 12:18 AM
12/01/17 12:18 AM
Las Vegas NV
MPCraig Offline OP
MPCraig  Offline OP
Las Vegas NV
Thanks Transman!! Any idea where I can get a cable that doesn't leave me in the poor house? Is it possible to reattach the shifter end, looks like it came loose, didn't break (attaches to shifter on dash)
Re: 1965 A100 Auto Trans Cable Question [Re: MPCraig] #2411620
12/01/17 01:41 AM
12/01/17 01:41 AM
Been a while since I looked at one but if I recall correctly the end was crimped on. If yours pulled out of the end ( shifter end is flat I think ) then try to reinsert it and crimp again. Or if it will insert again but not crimp maybe silver solder it? Let us know if that works.
My son is finishing up his A100 - I'll take a look at his cable and see how long it is. I just may have an extra cable buried in the garage somewhere.
Re: 1965 A100 Auto Trans Cable Question [Re: A727Tflite] #2411623
12/01/17 01:45 AM
12/01/17 01:45 AM
Las Vegas NV
MPCraig Offline OP
MPCraig  Offline OP
Las Vegas NV
Wow! That would be amazing if you could find one! Please let me know, I am helping my son finish his A100 project too!!
Re: 1965 A100 Auto Trans Cable Question [Re: MPCraig] #2411628
12/01/17 01:53 AM
12/01/17 01:53 AM
My son was close on his A100 then his uncle called him in 2011. When he got back from Afghanistan he started collecting what parts he was missing. Engine has to come back out as it has been setting too long but we are close to lighting it up. Good luck on your project.
Re: 1965 A100 Auto Trans Cable Question [Re: A727Tflite] #2411693
12/01/17 10:22 AM
12/01/17 10:22 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have several cables laying around. If you can't find one get me the length and I will see what I have. I have them both for A100 and D100, I am sure there is a length difference. shruggy
JB Rhinehart, Realist
A-Body's RULE!
