#2410646 - 11/29/17 09:54 AM What would be a better combination?
hupmobile1920 Offline
Loc: possum lake
For a while I have wanted a Gen III in my super bee.
I have gone round and round about what type of Gen III do I want to build.
With the advent of the Hellcat crate motors I feel that it would be a very " me too" thing to build.
I also like the Drag Pak type motors with the awesome sound.
What would you folks build if you could? Starting from a blank slate here so I can go in either direction.
Thanks for any advice
Gen III Types
Only one choice allowed
Votes accepted starting: 11/29/17 09:53 AM
View the results of this poll.
#2410656 - 11/29/17 10:04 AM Re: What would be a better combination? [Re: hupmobile1920]
BlakDak71 Offline
Loc: Michigan
Drag Pak style engines carry a lot of specific parts unless I'm mistaken, along with different valve train geometry. Hellcat or other production based engine would be "me too" because that's what everybody uses because parts are readily available and cheaper.
#2410684 - 11/29/17 10:45 AM Re: What would be a better combination? [Re: hupmobile1920]
ric3xrt Offline
Loc: Trumbauersville PA
Tough choice, an option your not thinking of, but might be better is a old school 8-71 on top of the G3, unless your dead set about keeping it under the hood or some from of scoop.
#2410724 - 11/29/17 12:25 PM Re: What would be a better combination? [Re: hupmobile1920]
WO23Coronet Offline
Loc: Canada
What are you using your car for? All out Drag Pack engines will put out comparable (probably more) hp than a stock hellcat but are nowhere near as street friendly (plus a hellcat is a pulley change away from glorious hp gains). They need gear and converter to work properly. A hellcat will be much more tractable and run better/faster with a combo that’s not optimum. It’s like comparing a 750hp 572 vs a 750 hp 360, both will be similarly fast with optimum set ups but waiver off the optimum and the 572 will stomp the 360 and won’t be such a nervous engine
#2410759 - 11/29/17 01:28 PM Re: What would be a better combination? [Re: hupmobile1920]
RTSE4ME Offline
Loc: MD
I would do a supercharged Drag Pak type engine with Whipple & new aluminum block.
#2411712 - 12/01/17 08:09 AM Re: What would be a better combination? [Re: WO23Coronet]
MattW Offline
Loc: Ontario Canada
iagree
Hellcat all the way!
25,623 Registered Members
195,510 Topics
A Body leaf springs
by rustyr
12/10/18 05:40 PM
71 Cuda in GY3 curious yellow
by fc7_plumcrazy
12/10/18 05:01 PM
Tired of gratuitous mockup pics yet?
by ZIPPY
12/10/18 04:56 PM
Looking for recommendation on 1968 RR Grill Restoration
by RalphsRapidTrnst
12/10/18 04:28 PM
