'02 Dakota caliper pins #2410225
11/28/17 06:16 PM
11/28/17 06:16 PM
Arlington, Texas
bobby66 Online content OP
bobby66  Online Content OP
Arlington, Texas
What size are the threads on the front caliper pins(bolts) on a 2002 Dakota. I've heard 9x1.25 but I wanted another opinion.
Re: '02 Dakota caliper pins [Re: bobby66] #2410466
11/29/17 01:07 AM
11/29/17 01:07 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Are you looking for the pins or need to retread the spindle?
Pins should be 04886075AA
Re: '02 Dakota caliper pins [Re: SALEM1912] #2410567
11/29/17 08:11 AM
11/29/17 08:11 AM
Arlington, Texas
Arlington, Texas
Got the pins, looking for the correct heli-coil or keenesert to repair the spindle.
Re: '02 Dakota caliper pins [Re: bobby66] #2411093
11/30/17 01:51 AM
11/30/17 01:51 AM
Arlington, Texas
Arlington, Texas
Bump.
Re: '02 Dakota caliper pins [Re: bobby66] #2411124
11/30/17 03:07 AM
11/30/17 03:07 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
some years back i bought a repair for disc threads,its a sort of epoxy,you put it on a bolt that is oiled or greased and screw it in,wait till it sets up then remove the bolt and the threads are there good as new,forgot what its called,i used it on a ford compact
my ladder of success is missing some rungs
Re: '02 Dakota caliper pins [Re: rhad] #2411529
11/30/17 11:24 PM
11/30/17 11:24 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I will ck tomorrow at work I have a kit and used it many times. Might ck NAPA for this set up; https://www.ebay.com/itm/Disc-Brake-Cali....m4383.l4275.c1
Tom
Re: '02 Dakota caliper pins [Re: bobby66] #2411604
12/01/17 01:05 AM
12/01/17 01:05 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
If the damage is done, then its done. These can sometimes clean things up and make it work. Lang Tools
Re: '02 Dakota caliper pins [Re: bobby66] #2411908
12/01/17 07:10 PM
12/01/17 07:10 PM
Arlington, Texas
Arlington, Texas
I may just drill o/s and tap to 10x1.5. 10MM shoulder bolts are pretty close in shaft diameter. Thanks for the help.
