Re: TIPM
[Re: kenworth_goose]
#2410547
11/29/17 04:15 AM
11/29/17 04:15 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
The tipm was the first signal for me to go back to 2 Gens. The "programmed to fail" feature in the new trucks is enough to keep an Owner awake at night.
I now have 5 Second Gens ranging from 55,000 miles to 300,000 so I hope I'm set for a lot of years.
Mo' Farts
Moderated by "tbagger".
Re: TIPM
#2427003
01/01/18 12:27 PM
01/01/18 12:27 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I have lost the right front fog light now, I will reinstall my original TIPM and see if it works and if it does looks like I'll be getting a 3rd TIPM! I did change the bulb. I have a circuit code in the bcm so it looks like the tipm.
Re: TIPM
#2431975
01/10/18 12:31 AM
01/10/18 12:31 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
Totally Integrated Power Module. How many have had the wonderful experience of having to replace the tipm on their late model Dodge and Jeep vehicles? I recently purchased a used 2012 Ram 2500 Crew cab 4x4. Right off the bat I had issues with the abs, traction control, transfer case, hvac module ect. After days of trying to diagnose the issues I finally figured it out when I lost my brake lights. Well 631.00 later I solved all of my issues but then a new problem came up. The Airbag light and the seat belt lights came on. After research on google I read about doing a hard reset when changing the tipm. What you do is turn the key on for 12 seconds and the tipm learns what it needs to relearn. That's supposed to be where the dealer comes in to relearn the tipm so the airbag light and seat belt light goes out. They call it waking up the air bag module. The dealer wanted 110.00 to program the tipm. Well guess what! Nothing needs to be reprogrammed. There is an IOD fuse that is in the tipm that comes not pushed all the way in. Such a scam by the dealer. Now keep in mind, I work in an independent repair shop and have for like 25 years. So I think it's fair to say I can find my way around a vehicle pretty well. Why would any manufacturer ever allow their dealers to be so dishonest? It just pisses me off. ....
Re: TIPM
[Re: tscuda]
#2431979
01/10/18 12:32 AM
01/10/18 12:32 AM
J_BODY
aZLiViN
Not just the dealers. The factory too. I bought a 87 d 150 new. The engine check light came on while on warrenty. Turns out there's a 9v battery behind the glove box. When it dies it throws a code so you have to take it in. that was required by the feds (EPA) back in the day as they wanted the emission systems inspected.
