Page 5 of 6 1 2 3 4 5 6
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408413
11/24/17 09:35 PM
11/24/17 09:35 PM
N. Hellinois
Sprayed 416 Offline
Sprayed 416  Offline
N. Hellinois
Originally Posted By Kindafast
Originally Posted By Transman
Mentioned 17 posts up - see Kunkels image. Hopefully the op checked for it - 👀
Thanks but it was checked out and was running and moving just fine for a few miles and then nothing.. That is the same support that has been with the transmission for a long time. None of the balls were missing . Thanks
That’s exactly what my transmission did with the blown input shaft seals. Drove car and put 10 miles or so the first time and about 15-20 the second time it happened. Was fine and then jumped in it the next day to go for a cruise and nothing.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408417
11/24/17 09:41 PM
11/24/17 09:41 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
I looked at the shaft seals and they seem fine. could you see the damage to yours ?
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408429
11/24/17 10:38 PM
11/24/17 10:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
have you checked the case it self for cracks at the valve body ports? could be causing an internal leak across two ports.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408456
11/24/17 11:33 PM
11/24/17 11:33 PM
Seaford, Va
Seaford, Va
I have looked at it some but not really inspected. I will do that tomorrow.
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408458
11/24/17 11:38 PM
11/24/17 11:38 PM
N. Hellinois
Sprayed 416 Offline
Sprayed 416  Offline
N. Hellinois
Yeah, the first go around one of the seals was gone completely. Second time the seal was Teflon, and was flattened and distorted. And as far as your friend with the Cope transmission, he’s the original builder of mine....
Re: Before I pull the transmission out again Question ? [Re: Sprayed 416] #2408489
11/25/17 12:54 AM
11/25/17 12:54 AM
okla.
sam64 Offline
sam64  Offline
okla.
just throwing this out there but the small thrust washer on the output shaft somehow didn't make it on one of my builds and it acted a lot like what you are describing.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408490
11/25/17 12:55 AM
11/25/17 12:55 AM
Seaford, Va
Seaford, Va
Are you talking about the two teflon seals on the pump or the steel seals on the input shaft ?
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: sam64] #2408493
11/25/17 12:57 AM
11/25/17 12:57 AM
Seaford, Va
Seaford, Va
The bronze thrust washer on the end of the output shaft ? Yes mine is there but thanks..
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2408587
11/25/17 09:53 AM
11/25/17 09:53 AM
N. Hellinois
Sprayed 416 Offline
Sprayed 416  Offline
N. Hellinois
The seals were on the input shaft, there’s 2 of them. The replacement seals were Teflon on my trans. They are in the pump area so I would say that they are the pump seals. Honestly, I don’t know anything about transmissions, just sharing what I was told to be wrong with mine as it sounds as you are having the same issue. But yeah, the seals were Teflon on the input shaft and was told when taken apart by original builder that he must of accidentally damaged the seal when installing the pump.
Re: Before I pull the transmission out again Question ? [Re: Sprayed 416] #2408594
11/25/17 10:39 AM
11/25/17 10:39 AM
Seaford, Va
Seaford, Va
Thanks for the info. I know just enough about transmissions to understand how they are supposed to work and mine don't LOL
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2410312
11/28/17 09:20 PM
11/28/17 09:20 PM
Seaford, Va
Seaford, Va
Update to anybody still reading this long story. Last ditch effort went ahead bought a new reaction support and oil pump for this thing. I also had A&A send me some new seal rings too. They should be here tomorrow. The case is not cracked but we did find the front alum drum with some groves in it from the seals. I was told that if anything it would cause a little problem shifting into high gear but wouldn't cause all my problems. Hopefully the reaction support and oil pump will fix this darn thing.
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2410322
11/28/17 09:32 PM
11/28/17 09:32 PM
A727Tflite Online content
A727Tflite  Online Content
If it fixes it take a good clear picture of the inside of the reaction shaft - the "tube" that's pressed in to the reaction shaft support. There are holes inside - take a few good pictures showing these holes and make sure you show the outside of the support too.
Re: Before I pull the transmission out again Question ? [Re: A727Tflite] #2410340
11/28/17 10:03 PM
11/28/17 10:03 PM
Seaford, Va
Seaford, Va
Will do !!
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2412290
12/02/17 04:54 PM
12/02/17 04:54 PM
Seaford, Va
Seaford, Va
Well the new pump did not fix it. I replace the complete pump asy and front sealing rings. No difference at all. I did check line pressure and found maybe 20 lbs of pressure in 1st gear , around 90 lbs in second and around 130 in high gear. I checked the rear servo and in reverse it had around 150. I turned the pressure up on the valve body but no change in my line pressure. Any ideas ?? The car will move if I rev it up but not good. " yes Mark I am still screwing with it " LOL
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2421534
12/20/17 06:35 PM
12/20/17 06:35 PM
HR3128 Offline
HR3128  Offline
Any update on this one?
I have a TF that acted the same way the last time it was in a car & has not been fixed.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2421630
12/20/17 10:33 PM
12/20/17 10:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The question I'd be asking is why is there only 20 psi in 1st. The only component applied in 1st is the rear clutch. Why does the pressure rise in all the other gear selections? The pump must supply even more volume to additional components that are applied in every other gear other than 1st. If there was an internal leak beyond the valve body 2nd and 3rd pressures should be even lower than 1st. Think on that.
Doug
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2421724
12/21/17 02:32 AM
12/21/17 02:32 AM
What tap did you check to get 20 in 1st, 90 in 2nd and 130 in 3rd. Be specific and accurate.
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2421729
12/21/17 02:42 AM
12/21/17 02:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am no trans guy,but I had a similar problem and it was the diverter valve that puts fluid to the converter shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2423082
12/24/17 02:08 PM
12/24/17 02:08 PM
Seaford, Va
Seaford, Va
Hey guys it's been a little while since I have been on here. Sorry for not replying . I figured out how to fix it. LOL
I bought a pretty new CRT Pro Race transmission from a good friend of mine. Works like a champ now.
On a serious note I never did figure out why the transmission just stopped pulling. Merry Christmas. !!!
6.50 @105.26
Re: Before I pull the transmission out again Question ? [Re: Kindafast] #2423128
12/24/17 03:55 PM
12/24/17 03:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
You know you can't stop now, way to much effort and work invested into fixing it, finish the job now! twocents
It's mechanical, not magic grin
