#2410225 - 11/28/17 03:16 PM '02 Dakota caliper pins
bobby66 Offline
Loc: Arlington, Texas
What size are the threads on the front caliper pins(bolts) on a 2002 Dakota. I've heard 9x1.25 but I wanted another opinion.
#2410466 - 11/28/17 10:07 PM Re: '02 Dakota caliper pins [Re: bobby66]
SALEM1912 Offline
Loc: Southeast Pa.
Are you looking for the pins or need to retread the spindle?
Pins should be 04886075AA
#2410567 - 11/29/17 05:11 AM Re: '02 Dakota caliper pins [Re: SALEM1912]
bobby66 Offline
Got the pins, looking for the correct heli-coil or keenesert to repair the spindle.
#2411093 - 11/29/17 10:51 PM Re: '02 Dakota caliper pins [Re: bobby66]
bobby66 Offline
Bump.
#2411124 - 11/30/17 12:07 AM Re: '02 Dakota caliper pins [Re: bobby66]
rhad Offline
Loc: garnett kansas
some years back i bought a repair for disc threads,its a sort of epoxy,you put it on a bolt that is oiled or greased and screw it in,wait till it sets up then remove the bolt and the threads are there good as new,forgot what its called,i used it on a ford compact
my ladder of success is missing some rungs
#2411529 - 11/30/17 08:24 PM Re: '02 Dakota caliper pins [Re: rhad]
SALEM1912 Offline
Loc: Southeast Pa.
I will ck tomorrow at work I have a kit and used it many times. Might ck NAPA for this set up; https://www.ebay.com/itm/Disc-Brake-Cali....m4383.l4275.c1
Tom
#2411604 - 11/30/17 10:05 PM Re: '02 Dakota caliper pins [Re: bobby66]
135sohc Offline
Loc: SoMd, USA
If the damage is done, then its done. These can sometimes clean things up and make it work. Lang Tools
#2411908 - 12/01/17 04:10 PM Re: '02 Dakota caliper pins [Re: bobby66]
bobby66 Offline
I may just drill o/s and tap to 10x1.5. 10MM shoulder bolts are pretty close in shaft diameter. Thanks for the help.
25,068 Registered Members
185,588 Topics
Fli Charge mat in older Chrysler vehicles?
by 360view
01/18/18 08:35 AM
TRAVELERS INSURANCE
by Magnumguy
01/18/18 07:16 AM
1.06" or 1.12" FF Torsion Bars, Street
by YO7_A66
01/18/18 06:54 AM
1968 Dart on CL
by RTSrunner
01/18/18 02:52 AM
