Page 9 of 9 < 1 2 3 4 5 6 7 8 9
#2061192 - 04/24/16 11:45 PM Re: Another Gen-III Hemi E-body swap [Re: GoodysGotaCuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
The ms3 is supposed to run it via pwm on the main board injector output but I don't think the frequency is high enough, still doing research...this alternator uses a positive voltage signal vs. the older ones that ground the field
#2063806 - 04/29/16 01:05 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I weighed the car tonight, the weight balance front to rear is better than I thought it would be an improves with me in the car
#2063928 - 04/29/16 10:21 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Mopar Mitch Offline
Loc: NW Chicago suburban area
ntstlgl1970 -- Did you disconnect the sway bar end links when you did the weight scaling? Try doing that and then re-weigh as you might find differences.... then re-attach the sway bar end links equally by shimming each end, assuming they are typical stock-style (pending your sway bar end link designs). Also, be certain tire pressures are where you want them to be, and of course with driver's weight included at the driver's seat.
#2064498 - 04/30/16 12:53 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I did not disconnect the end links since I was interested in seeing the total weight and f/r balance. I will try that though
Thanks!
#2404849 - 11/17/17 03:59 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
HP2 Offline
Loc: Right here
Any updates? I'm curious as hell, just started a 6.1 swap!
68 Dart GT ht project. Hemi clone..?
70 W100 Power Wagon. 318 4-spd
70 'Cuda vert 340 clone, In Violet, white interior and top
70 'Cuda 383 project.
70 Sport Fury 440 2dr HT, will get that 6.1 Hemi...
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
#2409041 - 11/26/17 08:15 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
AeroMonte Offline
Loc: S.E. Missouri
I'm starting a Hellcat swap into a 71 Cuda right now too. lots of learning to do
#2409190 - 11/26/17 02:28 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
Eric is still alive but he is not as active here or elsewhere.
#2420808 - 12/19/17 12:32 AM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I haven’t checked in for a while, but I’m still around. Need to get a pro to tune the engine and finish the interior
Edited by ntstlgl1970 (12/19/17 12:34 AM)
25,538 Registered Members
194,150 Topics
Race Ramps?
by davenc
10/22/18 09:57 PM
Enclosed car trailer hitch question
by 440mopar
10/22/18 09:44 PM
Convertible Challenger JS23 vin - rare
by Vert
10/22/18 08:53 PM
Wilwood brake quality/issues
by 73cuda340
10/22/18 08:01 PM
