#2408619 - 11/25/17 09:40 AM QA1 uca's
OSDart Offline
Loc: TX
Anyone using the QA1 tubular UCA's on a 65' Belvedere? We're you able to achieve a 4° or 5° positive caster? Any problems with construction or quality?
#2408722 - 11/25/17 02:00 PM Re: QA1 uca's [Re: OSDart]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
I was able to get 4.6 degrees of positive caster in my 70 Charger using poly strut rod bushings, STOCK upper control arms with the Moog K7103 offset bushings.
Another way to go, much cheaper and stock appearing:
Lower ball joint camber spacers/washers! AndyF makes them, Mancini sells them. They allow for more negative camber, which, along with the offset bushings, allow the car to get more caster without the camber going into the positive range.
#2408724 - 11/25/17 02:06 PM Re: QA1 uca's [Re: OSDart]
Loc: Granite Bay CA
25,074 Registered Members
185,647 Topics
U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios
by mloboda
01/19/18 07:46 PM
Not again!
by feets
01/19/18 07:35 PM
Anyone know this vendor at Detroit or Indy swapmeets?
by Stanton
01/19/18 06:55 PM
69 Cuda 340 value
by RMCHRGR
01/19/18 06:03 PM
