Re: Over Charging Problem 68 Dodge Truck
[Re: RapidRobert]
#2868130
01/02/21 03:30 PM
01/02/21 03:30 PM
Posts: 2,554 Maryland
wally426ci
Maryland
Happy New Year everyone. My charging issue has crept up again. Here is what I’ve done:
Truck was basically idle for a year or so with engine/trans build. Recently installed with good body grounds. Connections at firewall clean & snug. Fuse block cleaned. Truck runs well and would not notice this issue until 5 mins of driving or so.
Issue with previous charts as guide. I am trying to determine if this points to a particular component. Battery load tested well at a reputable battery shop. Squareback alternator with new style voltage regulator (triangular plug).
Readings (location, Idle voltage, 2500 rpm, engine off)
Battery positive terminal (12.16, 14.7, 12.53) Alternator stud (12.23, 19+, 12.53) Coil (10.36, 15+, 0) Top/center electronic VR terminal (11.27, 16+, 0)
+ sign means it was still climbing
Gauge, key switch and fuse block connections all clean & tight....
Greatly appreciate a bit of input.
[Re: wally426ci]
#2868278
01/02/21 10:08 PM
01/02/21 10:08 PM
wally426ci
Maryland
Robert, when I jump, should I get a multimeter reading at the gauge each time? And I presume jumping coil/regulator?
[Re: wally426ci]
#2868297
01/02/21 10:50 PM
01/02/21 10:50 PM
RapidRobert
we're dealing with a charging issue so we will work on the charging components. jump from batt positive terminal to the top (blue wire) terminal on the reg (stick a thick pin/wire in to get continuity). jump from batt neg post to the reg case. pull the 2 wires off of the alt field terminals (dont let em touch ground). jump from one male alt field terminal to the battery positive terminal. jump the other alt field male terminal to the green wire in the reg connector (use a thick pin/wire). jump from the battery positive terminal to the large alt threaded stud. jump from the batt negative post to the alt case (you might use your jumper cables for this if they are secured good or have a helper hold them). fire it up to a fast idle & see what voltage you get at the battery. only have it running for a few seconds 10 or so (long enough to get a reading) as full fielding from a bad component/grounded wire will fry things in short order. have all lights/radio etc off. I dont think I missed anything. this elims everything except the alt/reg/battery. EDIT we could jump one at a time but that is too much full fielding. you might pull the alt brushes & a visual there, they are a frequent culprit. my gut says alt or reg
[Re: RapidRobert]
#2869344
01/05/21 02:52 PM
01/05/21 02:52 PM
Posts: 19,239 north of coder
moparx
have you had the brushes out and closely examined the isolated brush holder ? what does the armature look like ? also, are the male connections to the brushes clean and tight ?
[Re: moparx]
#2869580
01/06/21 05:40 AM
01/06/21 05:40 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
Have you tried remove the alt and spin by hand to check some friction, contact or weird feeling when spinning? May have not necessary remove the alt but just loose the belts and feel it.
I had once my alt giving up to 18volts at iddle ( more giving RPMs ) but no charge on ammeter ( some charge when giving RPMs ). One of the stator lead to diodes was making contact with just one of cooling vanes on rotor when spinning. Hard to feel but I was able to feel a small "stop" similar to the elect distributor stop due the magnet with reluctor points when spinning. Dissasembled, bent the wire a bit and done.
[Re: moparx]
#2869657
01/06/21 12:17 PM
01/06/21 12:17 PM
wally426ci
Maryland
have you had the brushes out and closely examined the isolated brush holder ? what does the armature look like ? also, are the male connections to the brushes clean and tight ? Good points all! I'm wallpapering this week, but will get back to it this Weekend.
[Re: wally426ci]
#2878010
01/21/21 06:56 PM
01/21/21 06:56 PM
wally426ci
Maryland
I appreciate everyone's help here. At the moment, I have a tentative fix (until I drive it more).
I double checked connections and grounds and did not find an issue. I kept thinking it was mechanical, because it would run fine for 5 minutes and almost switch to the high voltage. That told me it wasn't a connection.
I cleaned my Alt brushes and at the same time I replaced the VR. I am back to my original 14.7 idle to 14.5 readings at the gauge & across terminals/alternator, so I am hopeful that it was mainly the VR since the brushed looked fine to the eye. Keep ya'll posted (again)!
I have yet to jump anything, but I have that well documented in case this happens again.......
